Hitachi E coil update....
Old Apr 25, 2007 | 09:09 AM
Matt Devo's Avatar
Default Hitachi E coil update....
<a href="https://forums.audiworld.com/a4gen2/msgs/1041857.phtml">Previous post</a>
after the events in the above post, I pulled the coils and checked the plugs, and everything appeared fine. Plugs are NGK BKR6EIX iridium plugs, with ~5k on them.
wife's car misfired again on cold start on way home from work yesterday, same symptoms as before, rough idle with flashing then solid CEL once idle returned to normal. Scanned the codes, and got the following:
Random Multiple cylinder misfire (sporadic)
Cylinder 1 misfire (sporadic)
Cylinder 2 misfire (sporadic)
Cylinder 3 misfire (sporadic)
Cylinder 4 misfire (sporadic)
If there were ever any misfires with the "newer" coils, they were not enough to set off a CEL. I'm going to put the "new" coils back in and see if the misfires persist. GRRRRRR
Old Apr 25, 2007 | 09:18 AM
Ming02's Avatar
Default Could moisture have gotten into the down tube to the plug?
I say this because even though there is a gasket on the Hitachi's it is completely useless. If you look there is a rectangular ridge running around the sparkplug hole, this ridge forces the coil to sit off the surface making the gasket ineffective. I'm concerned that moisture will work it's way to the connection with the plug and cause problems. This is probable as the connection to the plug is nothing more than a spring with no rubber sealing boot.
I plan on grinding down this ridge on the head of my engine to get the coil to seal. I will also be using some dialectric grease on the plug connection. Using the grease regardless would not be a bad idea under any circumstance.
Old Apr 25, 2007 | 09:34 AM
Tgr_Clw's Avatar
AudiWorld Uber User
I got my set installed today. Seems fine so far. I'll keep an eye on it.
Old Apr 25, 2007 | 10:23 AM
psuaudi's Avatar
i have weird misfires as well...OEM coils though
Old Apr 25, 2007 | 10:43 AM
Tgr_Clw's Avatar
AudiWorld Uber User
So replace a coil or two.
Old Apr 25, 2007 | 12:33 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default I had simular problem...
and switching from Siemens injectors to Genesis cured my misfire codes.
Old Apr 25, 2007 | 01:20 PM
Matt Devo's Avatar
this is on a currently stock car (teh wifey's) engine-wise
Old Apr 25, 2007 | 01:36 PM
Tgr_Clw's Avatar
AudiWorld Uber User
Default How about trying the Hitachis on your car for while? That'll determine whether it's the...
Hitachis or something else.
Old Apr 25, 2007 | 02:31 PM
wellused's Avatar
How is your idle now?
Old Apr 25, 2007 | 03:44 PM
diagnosticator1's Avatar
Default Just fill the boot with dielectric grease. You won't have any problems from water down there.
The grease is just a precaution anyway.
