Idle problem when cold
Old Feb 14, 2013 | 07:55 PM
vali_podaru's Avatar
Default Idle problem when cold
Hi guys, turns out that I have another small problem now..I have a 02 A4 3.0 quattro 6 speed manual. When the car is cold, even 20 minutes after I started and drove a little bit, if I wanna stop to a light and if I press the clutch the rpm will go up with like 500...then down a little bit under 800 and then stabilize. I doens;t seen that the engine will die..but its not nice, and also not fuel efficient. Can somebody tell me in which direction I should start the diagnostic? Thank you and hopefully I explained well.
Old Feb 15, 2013 | 02:29 AM
auditechstef's Avatar
tell me abit about the car and history.im sure i can help you with this problem.
Old Feb 15, 2013 | 04:31 AM
SilverSline's Avatar
I would check for any faults first if you can. Possibly a throttle body cleaning/adaption could help, but you have to rule out any vacuum leaks or other problems first.
Old Feb 15, 2013 | 06:10 AM
Ok, I was thinking to do a vacuum check anyway. Car history..it has 115k miles, new air filter like 1k ago, new fuel filter (1k ago). Also the valve cover gasket has a small seep (its not very bad, i dont see oil on the ground, just sometimes when I go to higher rpm I can fell an burned oil smell).
Old Feb 18, 2013 | 11:05 AM
Hi again, yesterday I realize that this happens also when the car is warmed up..like after 1 hour of driving. Should I be worried?
B90Coupe
Mar 10, 2009 02:56 AM
mofologic
Jul 16, 2007 01:46 PM
MiB@100-2.3NF-91
Jun 2, 2005 05:56 AM
mint875000cstq
Jan 27, 2005 06:30 AM
diamond8990
May 28, 2002 04:48 AM
