Missing Sensor?
Old Apr 3, 2010 | 02:27 PM
bboissonneault's Avatar
Default Missing Sensor?
Need your help...
2002 A4 Quattro 1.8t tiptronic
I was doing a lower control arm job today when I happened to look in the wheel well on the driver side and noticed a machined hole, about 18-20mm in diameter with a tapped hole next to it. I could see the teeth of the flywheel through the larger hole. It looks like some time of sensor should be there. Am I missing some kind of Hall sender?
Old Apr 11, 2010 | 03:48 PM
Bump...
I should mention. The hole is on the drivers side of the bell house. It is very near the back of the engine, as the teeth of the flywheel can be seen.
Old Apr 17, 2010 | 07:24 AM
alex.syed's Avatar
Originally Posted by bboissonneault
Need your help...
yeah that hole is probably there from the start you should be fine..or beleive me those cars are sensitive, ur check lite would have turned on rite away. Once i made a mistake like that once for a small sensor and my check lite appreared
Old Apr 17, 2010 | 02:50 PM
AudiCO's Avatar
Bump...
I searched my entire Bentley manual to try to find an answer the other day but came up with nothing. I was under my car yesterday changing the fuel filter, but I have a manual transmission so I can't really relate. Pictures usually help in this type of situation.
Old Apr 19, 2010 | 03:32 AM
Thanks all. I have had no lights, or issues of any kind. I will try to post a picture later though, just to be thorough.
Old Apr 22, 2010 | 04:11 AM
lyleswk's Avatar
I was perusing through another Audi forum and someone suggested it was used to set the timing on the car. The owner in the other forum had a 3.0, but would think Audi would use something similar on the 1.8T. I still haven't had a chance to look at mine...
Old Apr 22, 2010 | 10:52 AM
Pete@ECSTuning's Avatar
Audiworld Basic Sponsor
Your description is a little foggy, but it sounds like that is the normal viewing hole in the crankcase that allows for reading of timing marks and visual inspection on the flywheel.
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
jgospodaric
Audi allroad
Jun 23, 2016 11:32 AM
bboissonneault
1.8T Discussion
Apr 2, 2010 02:43 PM
2low4snow
Oct 6, 2006 04:21 PM
XCLR8TT
Jul 7, 2005 10:02 AM
UK_A4_Owner
12v V6 Discussion
Jul 2, 2003 01:38 AM
