Need Help!!!!!!
Old Mar 30, 2003 | 04:45 PM
SoCalA41.8T's Avatar
New Member
Default Need Help!!!!!!
<center><img src="http://pictureposter.audiworld.com/41856/pics2_011.jpg"></center><p>
After I did this......
Old Mar 30, 2003 | 04:47 PM
New Member
Default Now I got THIS??????
<center><img src="http://pictureposter.audiworld.com/41856/pics2_021.jpg"></center><p>
Old Mar 30, 2003 | 04:48 PM
Senior Member
what? your lights arent level? all out of whack?
Old Mar 30, 2003 | 04:49 PM
New Member
NOPE they are perfect, BUT I GOT THAT
Senior Member
Default Autoleveling is whack...did you unplug anything other than the light plug?
if you didn't you have to clear the code. Did you remember to plug the autoleveling motor back in when you were gutting out the light assembly?
Old Mar 30, 2003 | 04:51 PM
New Member
NO I only unplugged the light, what do i need to do to fix it
Old Mar 30, 2003 | 04:53 PM
Senior Member
Default take the lights out...verify that the connector for the leveling motor didn't
get unplugged. Start the car and see which light is not going through the leveling motion. do you have access to a vagcom? you may just need to go in and clear the code. that happened to my friend's car cleared the code started the car and it started working again.
Old Mar 30, 2003 | 04:54 PM
sj audi's Avatar
try taking them out and putting them back in, making sure everything is proper...?
 Michael S. Palmer
Old Mar 30, 2003 | 06:37 PM
ATL-B6's Avatar
New Member
You may have thrown a code--check VAG.COM
Old Mar 30, 2003 | 07:32 PM
lawong's Avatar
Default Agree with ATL-B6. You threw a code. You'll need someone with a VAG-COM to clear any DTCs.
The headlights are on the 09 - Electrical Module. Its most likely a simple fix like clearing your codes. Then it will return to working mode. You'll also notice that your auto-leveling is broken because of the DTC (if you have Xenons).
