Need help...codes
Old Mar 31, 2008 | 04:02 PM
A4driver1point8's Avatar
Junior Member
Default Need help...codes
i still have the P0171 and P0507 codes. Saying system bank 1 running too lean. I have checked everywhere for vacuum leaks....can't find anything. My car is idling very rough and hesitating. What is going on here???
Old Mar 31, 2008 | 04:46 PM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default Some good info here-
-<ul><li><a href="http://search.audiworld.com/?q=P0171&amp;u=&amp;s=all&amp;cat=010022&amp;db=19 99-01-01&amp;de=2008-03-31">http://search.audiworld.com/?q=P0171&amp;u=&amp;s=all&amp;cat=010022&amp;db=19 99-01-01&amp;de=2008-03-31</a</li></ul>
Old Mar 31, 2008 | 05:10 PM
Junior Member
Did that already.
Old Apr 1, 2008 | 05:36 AM
MikTip's Avatar
AudiWorld Expert
25 Year Member
Default You checked the "L" hose...
...<ul><li><a href="https://forums.audiworld.com/a4gen2/msgs/1054943.phtml">https://forums.audiworld.com/a4gen2/msgs/1054943.phtml</a</li></ul>
Old Apr 1, 2008 | 11:58 AM
diagnosticator1's Avatar
Default The lean mixture codes, with the rough idle, and hesitating. is consistant with ...
a vac leak somewhere.
Just because you have not found the source, doesn't mean is does not exist. In this case, the leak "false air" flow is highest at idle, when manifold vacuum is highest. (absolute manifold pressure is lowest,) and is effecting the fuel mixture the most. As throttle opening angle increases, manifold vac decreases, the leak false air flow decreases, and effects the fuel mixture less, as load increases. Focus on the system hoses and connections to the manifold AFTER the throttle valve.
Less likely, is low fuel pressure at the injector rail. Check to confirm. Also, try disconnecting the MAF meter and start the engine and see if the rough idle improves, if it does, the MAF is probably bad.
