obdII reader draining battery?
It wasent that cold outside, and the only thing different now is I had the obd reader plugged in for the past few days, so I'm trying to figure out weather the obd reader caused a parasitic draw that drained the battery over the weekend? I checked if I left the headlights or any interior lights on, but coudnt find anything that would drain the battery. The last time the battery died was in an equally sudden and mysterious manner, but I chocked that one up to the battery being old.
One think I did notice is regardless of weather the engine is on or off trying to raise the windows when they're already closed, dims the headlights just a bit. That does seem to lead towards a charge issue, just not to the extent you've described.
I leave it parked there, and come back later in a buddy's car with a pair of jumper cables, only to find out somehow the voltage was back up enough for a single crank (it was low but enough to crank over the engine), so I'm very confused.
Every time I've checked the battery voltage while the engine is on its been near or above 14V so the only other option is some sort of parasitic draw, but I'm hard pressed to think of any sort of parasitic draw that can drain the battery that much over the span of just an hour or 2.
So, I will go back to my original questions.
1. Have you checked the electrolyte levels in the battery?
2. How much over 14V are you getting out of your alternator? I ask because perhaps your voltage regulator has failed, the voltage is too high, and you have cooked your battery.
What is the voltage of your battery after you charge it with your engine off?
Depending on how discharged the battery was the voltage while the engine was on hovered between 3.6v and 14.2v. After turning off the engine it dropped gradually to around 12.5v. That all seems pretty normal to me, but I'm by no means an expert on this and have only started researching this stuff after these recent issues.
