Oil problem... maybe?
The oil light only comes on after 15 or 20min of driving but the engine light is steady. No loss of power or anything? Anyone have an idea, i know its odd. I have a VAG-COM and see if i can pull anything later.
I know probably risky driving like that, but the car seems ok... again i didnt push it. Thanx.
If you don't have valve train tapping sounds and oil is filled, and sludge is not an issue that leaves electrics.
My 2 cents.
I'm currently at 65k miles and had my last oil change at 59k and they used Synthetic... I only remember this cause I asked about Oil Sludge issues and he re assured me they use synthetic.
I'll check the sensor and see if i can scan it. Thanx guys!
Currently at 65k miles, and had the last oil change & 60k maintenance done at the dealership at 59k. Previous to that all dealership, but different owner.
According to the dealership when i spoke to them at 59k miles they said it was Synthetic but nothing mentioned of brand of any sort. Thanx.
Switch will change from open circuit (Eng not running)
To closed circuit (below 50 ohmns or so)with eng idling.
(check using volt/ohmn meter with wire disconnected.)
