One quick statement...
Last year I had only the STaSIS TorSen mod on the car and I could tell it made a difference.
However, this winter the TorSen mod is joined by the STaSIS LSD mod and <b>WOW</b> the car is all over the place. You want oversteer? Your wish just came through. This car now drives almost like a BMW, that's how tail happy it is. I think the wife would crash it if i let her drive it. Mind you I drive with the ESP off all the time. Can't wait until next spring to see if the STaSIS Motorsport suspension can help me that kind of oversteer on the dry.
That is all for now.
The regular OEM TorSen under normal driving situations does provide a 50/50 torque distribution. However, under abnormal or slippery conditions it can and will transfer up to about 66% of the torque to which ever axle requires it (front or rear). That means the other axle is only left with 34% of the torque. The regular OEM TorSen is said to have a 2:1 ratio.
Now the STaSIS TorSen mod changes that ratio to 4:1. It remains a 50/50 unit under normal driving conditions. However, it will under abnormal conditions transfer up to 80% of the torque to either axle leaving the other with only 20%. So under most acceleration situations, like coming out of a curve or turn on the track, because of the weight transfer towards the back, the front wheels lighten up and the TorSen senses this and redirects more torque towards the rear wheels, making the it a bit more like a RWD car. Keep in mind the TorSen works in a front to rear and vice versa manner.
Hope this clarifies the TorSen issue.
Now the limited slip differential (LSD) works on the rear axle in a side to side manner. It is set at 60% lock out. Both wheels turn in the same direction because the LSD acts like a locking mechanism until a sufficient amount of load or torque breaks it out. Until that limit is reached both wheels push the car through a turn or curve, no inner wheel spin can occur. So you always have traction. This further makes the car handle like a RWD car. You can definitely get power on oversteer, a lot more and easier than with just the TorSen mod. One draw back to this unit, its price, $1895.00 + shipping, taxes and installation.
Hope this as clarified for you all the differences between the two mods.
O, and thanks for the clarifications!
Disconnect the abs,
throw out the air bags (they just add weight), Seat belts with shoulder straps are for wimps.
Consider also getting rid of the electric starter and install a crank coming out of the front grille.
(Just joking with you Jet.)
