Problems using gear for parking
Old Jun 10, 2002 | 09:02 AM
Dolphin Dee's Avatar
New Member
Default Problems using gear for parking
Folks,
When parking - especially on hills - I always place the car in gear in addition to the parking brake as with any manual. I undid my parking brake a couple of days ago and the car was not stopped by the gearing. Kind'a scary should the brake ever fail.
Thing is, it seems to be intermittent. However, I can't seem to reproduce an exact sequence of events (shifting in gear before turning off the engine, shifting in gear after turning off the engine, 1st vs. 2nd gear, etc.) that will cause one or the other.
Any ideas?
Thanks.
Old Jun 10, 2002 | 09:15 AM
woofpup's Avatar
Senior Member
Default Re: Problems using gear for parking
Well, usually it's expected that you always use the parking brake on a hill, even if it's in gear - that goes for whether you have a manual or an automatic (even if it is in Park).
With a manual, the reverse gear is generally the best to leave it in, although in some situations you should use 1st gear.
Anyone else have anything to add?
Old Jun 10, 2002 | 09:17 AM
New Member
Thanks. I DO use my parking brake. The thing is that the gear doesn't always hold, whether in reverse, first, second. So if the parking brake happens to fail...
Old Jun 10, 2002 | 09:19 AM
woofpup's Avatar
Senior Member
I know... I just mean that I don't think there is any guarantee with any manual transmission car that it'll stay in place if your parking brake fails.
That's part of why you should also turn your wheels in toward the curb when you park, so at least it won't roll straight back if something like that were to happen.
Old Jun 10, 2002 | 09:27 AM
motorwaffen's Avatar
Elder Member
Default yeah, the gear won't hold--just turns engine...
I did that once on my driveway (steep), come outside to find my A4 slowly rolled into the road...but hit no one! (whew!)
Old Jun 10, 2002 | 02:58 PM
jlew's Avatar
Leaving the car in gear doesn't lock anything... Basically, you're just using engine compression to make it more difficult to move the car. It will hold the car on a flat or small grade, but not on a steeper one. Whenever I park, this is my sequence:
1. Set P-Brake and release foot brake so that the parking brake is the only thing holding the car.
2. Turn wheel about 1/2 turn from straight (towards the curb if facing down hill and away if facing up hill) so that if the brake fails the tread of the tire will roll into the curb and hold the car without damaging the rim.
3. Put the car in first gear (or reverse... no diff) as a "last resort"
4. Turn the car off, walk away and look over my shoulder. Never forget to look over your shoulder!
Monsoonenough
S4 (B8 Platform) Discussion
Oct 3, 2015 02:59 PM
S4intheOC
Sep 8, 2015 12:12 AM
Clarence Willie Mays
Sep 6, 2015 10:30 PM
Sep 4, 2015 11:09 PM
stormchaser1967
Sep 2, 2015 09:26 AM
