Program key to car on a 2002 audi a4
Old Oct 11, 2009 | 12:39 PM
02 A4's Avatar
Default Program key to car on a 2002 audi a4
I have looked around alot and have not found any instructions that work. i have a new key and i need to program the remote to the car and i am having no luck so can anyone help?
Old Oct 12, 2009 | 10:13 AM
AzIvy75's Avatar
The dealer has to program it. :-(
Old Oct 12, 2009 | 10:17 AM
02 A4's Avatar
i heard that there is a guide that tells you what to do and how you do it does anybody have any websites or guides for me?
Old Oct 14, 2009 | 06:22 AM
diagnosticator1's Avatar
Default Check for instructions on Ross-Tech.com
Check for instructions on Ross-Tech.com you will need VCDS/VAG-COM.
Old Oct 14, 2009 | 04:11 PM
02 A4's Avatar
thats what everyone tells me but i dont know where to find one of those computers
Old Oct 15, 2009 | 08:00 AM
AudiDriver's Avatar
Hey 02 A4, try one of these two similar sets of instructions, you may have already tried them, but I'll post again:
1st Option:
 Programming Remote Unit:
- Switch ignition ON.
- Lock vehicle mechanically at left front door using second key.
- Press "Open" button on first remote unit (key fob) once (to assign memory address to remote unit number one).
Note: The alarm horn will sound briefly each time the "Open" button is pressed to confirm the reception of the signal during this process.
- Wait six seconds after sending last signal, then press "Open" button again.
>Doors will now unlock (remote unit is now programmed).
- Lock vehicle mechanically again using second key.
- Press "Open" button on second remote unit (key fob) twice at 1 second intervals (to assign memory address to remote unit number two).
- Wait six seconds after sending last signal, then press unlock button again.
> Doors will now unlock (2nd transmitter is now programmed).
- Repeat procedure for additional remote units (key fobs) to assign memory addresses number 3 and 4 if necessary.
- Switch ignition OFF.
- - Check each transmitter for proper function.
2nd Option (similar)
 Take one key and put it in the ignition and turn the ignition ON.
- Close and lock the driver's door with the second key (while the ignition remains on).
- Take the first remote and press the "UNLOCK" button ONCE only - alarm will 'beep' but door will remain locked.
- With the key, unlock and lock the door again.
- Test the remote by pressing the "UNLOCK" button again - door should unlock.
- Open the door and turn ignition off and back on again using the first key
Let me know if this is what you were looking for.
- Joe
Old Oct 15, 2009 | 03:13 PM
02 A4's Avatar
i have tried the 2nd one but something simliar to the 1st i asked a buddy of mine that used to work at champion audi and he said after 2001 u need the vag computer
Old Oct 15, 2009 | 10:34 PM
wzlc's Avatar
Banned
Thank you for sharing.
Old Jun 8, 2014 | 05:03 AM
michael_3adel's Avatar
Default Its dosent work
1st Option:
- Joe
Hello joe,
I tried many times the steps above & it dosent work, my remote was working normal until i changed the battary then the remote stop open or close the car noting that car already see the key as its blink when i open the ignition & put the other key in door & then press unlock then its blink & when i remove the key from the door its blink too so if u have any solution for my issue please tell me my car audi a3 model 2002
Thanks
Michael
Old Jun 9, 2014 | 05:21 AM
lyleswk's Avatar
Well, I'm sure "Joe" is not around anymore. This thread is 5 years old.
I had an 02 and understand that the CCM is an older configuration and could only be programmed by the dealer. After trying this and several other suggestions for several weeks, I finally gave up and went to the dealer to have it programmed. Will note that depending on where you got your key, it may still not work...
QuickChange
Sep 4, 2015 06:51 PM
icecam
Aug 31, 2015 07:44 PM
2k6blacka8
New Member Welcome Area
Aug 30, 2015 04:13 PM
2k6blacka8
Aug 30, 2015 02:07 PM
Janryk
Aug 30, 2015 02:12 AM
