shifting problems
The TB just makes a ton of racket before it goes and stops making the noise when you push in the clutch. If the clutch pedal feels weak but still gives some resistance you probably have air in the lines or moisture. Bleed them out and check, it's all about diagnosis.
http://audi-diy.blogspot.com/2007/10...cement_29.html
there are some pictures on that site. you will need a pressure brake bleeder kit.
pumping/ or use of vacuum pump does not work or well at all on these cars..
may i ask where you are located? if you're nearby i could help you out.
