stage 1+ problems
EDIT: There is an adaptation channel in the IC that can partially offset the calibration error, and improve the DIS MPG accuracy.
This has also been my experience; the DIS keeps proper mileage with stock flow rate injectors, and keeps inaccurate but consistent mileage with higher-flow injectors. The only variable I can think of that skews the linearity of this calculation back to the stock calc is the apparent hard-coded maximum of 40L/100km (or equivalent) that the DIS records, even when >40L/100km of fuel is flowing into the intake. Not sure if that's a DIS display issue or if the actual calculation has that maximum in place.
The adjustment channel is nice, but doesn't provide enough headroom to compensate for the 380cc/386cc injector flow rate
I concure about the limited range of the adaptation channel though, it could have been wider.
