Swap HVAC Controller - Basic settings
Thanks, Mike.
But back to your problem, to reset the vehicle data in the A/C controller, store PIN "26467" in adaptation channel 081. Doing this resets the A/C controller with the VIN for the vehicle the controller is installed into by getting the VIN from the instrument cluster. Reset the A/C to basic settings by opening measuring block 000, and waiting for the values return to the base value of zero for each data block shown.
The A/C controller PN with a different suffix will work, provided the PN suffix is for a 2002>2005 B6 A4/S4.
What's Up?
From de.OpenOBD.org,
The controller coding is as follows,
"00XYZ" where X=0, Sedan, Avant and Coupe
X=1, Cabriolet.
Y=0, Heated windshield, NOT installed.
Y=1, Heated windshield installed.
Z=0, Sun roof with solar electric panel Not installed.
Z=1,Sun roof with solar electric panel installed.
Therefore, the controller coding to enter via function 07, for a Sedan without windshield heating or the sunroof solar electric panel, is
"00000".
The Cabriolet coding is "00100"
Use recode the controller with "00000", and see if the rear window defroster is activated. The heating grid in the rear window will not be energized if the temps are above about 45 deg F, even if the system is activated with the recode.
Thanks,
Mike
After opening the controller with VAG-COM., The radio button that says "Coding 07" is clicked to open the recode controller window. See pic. Also see link to online demo manual for a step through.<ul><li><a href="http://www.ross-tech.com/vag-com/tour/main_screen.html">http://www.ross-tech.com/vag-com/tour/main_screen.html</a</li></ul>
Thanks a million,
Mike
