syncro-mesh
Old Nov 15, 2004 | 06:49 AM
GDawgA4's Avatar
Default syncro-mesh
how durable are syncro-meshes? when I was downshifting, while letting out the clutch, I hit a bump and knocked my foot off the clutch so it came out pretty quick. After the clutch came out, there was a "jolt" feeling, i'm guessing from the syncro's doing it's job. Did I do a great deal of damage to it? eek...
Old Nov 15, 2004 | 07:52 AM
ScottJ's Avatar
Default Syncro-mesh is a type of GM trans fluid.
A synchro is the brass or bronze ring in your tranny that keeps you from grinding gears on shifts.
There're pretty durable. Hard to mess them up with just one bad shift.
Old Nov 15, 2004 | 07:54 AM
GDawgA4's Avatar
whoops, still learning my manual terms =D Thanks for the info.
Spinnetti's Avatar
Default Re: syncro-mesh
Hmm.. How to answer..
1. Its one word 'syncromesh' (no biggie)
2. The job of the syncros is to match the speed of the two trans shafts so that when the gears come together, they 'mesh'. Without syncros, you can shift smoothly, but you have to match the engine rpm for the gear you are going into relative to the speed you are going (easier done than explained). In fact, if you are good, you can shift without the clutch entirely (except first of course). I used to do that in my Rabbit all the time, but never tried it in the A4.
3. The jolt you felt was your abrupt clutch engagement - nothing to do with the syncros.
4. Syncros are not that durable - they are made from bronze/brass. If you had really bungled it, the gears would have ground - they syncros will match, but don't prevent you from grinding the gears if you work at it, or in this case if your foot falls off the pedal.
Old Nov 15, 2004 | 07:55 AM
GDawgA4's Avatar
yeah, no grinding gears, just the jolt right after the clutch came out.
Old Nov 15, 2004 | 08:55 AM
AlbA4's Avatar
New Member
Default Sycros come into play when you move the shifter, not the clutch...(m)
although I could be wrong.
greatwhitepaper
Jun 2, 2002 01:29 PM
