Tech help....
Old Mar 23, 2004 | 09:50 AM
A4NCAR's Avatar
Senior Member
Default Tech help....
Is it difficult to remove ECU box and remove/install injectors? Any instructions, pictures, advice, warnings? Much appreciated.
Old Mar 23, 2004 | 09:56 AM
SP (oenophile)'s Avatar
Junior Member
Default Re: Tech help....
Sup Dood ^_^,
You are referring to fuel injectors right? If so, here's an instruction from APR website:
http://www.goapr.com/Audi/support/ecu_a4_b6_injectors.pdf
Hope it helps ^_^
Old Mar 23, 2004 | 10:07 AM
shadyraven's Avatar
Senior Member
APR's site also included details instructions (with pics) on how to remove the ECU.
Old Mar 23, 2004 | 03:12 PM
bhvrdr's Avatar
Not hard at all. Shoot me an email when your ready to do it. Ill give you my ph. no.
Old Mar 23, 2004 | 03:16 PM
A4NCAR's Avatar
Senior Member
Default It might be around 8-9pm PST though.
If you're able to just roughly type it up, that should help. I have the APR DIY instructions also.
Old Mar 23, 2004 | 03:19 PM
bhvrdr's Avatar
Just checked APRs website. Those instructions are right on.
Old Mar 23, 2004 | 03:54 PM
A4NCAR's Avatar
Senior Member
Default Thanks!
I was going to ask if there were any special tools required (I haven't looked at that DIY instructions yet and I don't have a huge selection of tools).
Old Mar 23, 2004 | 06:12 PM
A4NCAR's Avatar
Senior Member
Default I looked over the APR DIY instructions and it looks easy.... but
only thing is the rotary tool with cut off wheel for creating the flat head screw driver slot in the security screw. Isn't there another way to remove the security screws? Jet Jockey mentioned heating them up because they use some wax or seal on them. How does the dealer do it?
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 23, 2004 | 06:49 PM
bhvrdr's Avatar
You can acutally get them off with a set of vice grips. It takes some finesse but can be done.
Old Mar 23, 2004 | 06:51 PM
A4NCAR's Avatar
Senior Member
So grip the top and pull, or twist/turn?
