Vcds coms error
Old Jul 1, 2020 | 02:59 AM
Richard Dite's Avatar
Default Vcds coms error
Right peeps got an a4 b6 fitted cruise and cant get vcds to talk to steering control module comes up with to many communications errors to continue read online it could be cheap lead but same lead works perfectly on my other 2 a4s it also says same on central electrics also tryed 2 diferent laptops and 2 other completly different setups ie mate vcds also when the vcds is trying to read the part numbers serials to get the info from steering control first i have ines where the numbers should be ie l l l l l l l the is finds t some numbers but look like they are corupted as instead of numbers it has leters somtimes symbols any one shed some light please
Old Jul 2, 2020 | 01:55 PM
A4Audi4Fun's Avatar
Can u communicate with any of the other modules in the car? Battery voltage in good shape? Are the contacts into the OBD plug clean?
Old Jul 2, 2020 | 10:36 PM
Default Vcds to many com errors
Yes thanks for the reply i can get into engine and a few others contacts clean battery good realy doing my nut in now
Old Jul 3, 2020 | 04:41 PM
Geomeo's Avatar
The communications uses k-line which is a bi directional line. Meaning any module ecu tcu etc etc only needs one wire to work. That and power to the module of course. So what you’re looking for to test is power to the module that you’re trying to communicate with. And continuity I believe it’s pin 7 on the obd port to one of the pins (don’t have a diagram) on the module itself. If all those are fine then it will be the module itself. If you google Bosch ecu pinout Kline from some of the images you’ll get a general idea how it works.
Calhu9
Q5/SQ5 MKI (8R) Discussion
Nov 11, 2017 06:22 AM
nirad
Aug 3, 2007 06:51 AM
PetrolDave
Oct 12, 2005 06:30 AM
PetrolDave
VAG-COM Discussion
Oct 11, 2005 11:57 PM
53freak
VAG-COM Discussion
Oct 17, 2004 06:41 AM
