A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
*** Forge Motorsport Replacement Vacuum Operated Piston Diverter Valve for VAG 2.0 FSiT ***
Old Aug 17, 2008 | 08:10 AM
Parts4Euro.com's Avatar
New Member
Default *** Forge Motorsport Replacement Vacuum Operated Piston Diverter Valve for VAG 2.0 FSiT ***
Dear Members,
Forge Piston Diverter Valve for VAG 2.0 FSiT
<b>FREE SHIPPING WORLD WIDE!!</b>
<a href="http://www.parts4euro.com/DCShop/product_info.php?cPath=2_47_208&products_id=367">< b>PLEASE ORDER HERE</b></a>
<img src="http://www.forgemotorsport.com/images/products/FMFSITV.jpg">
Please See below for more information from Forge Motorsport's Website
We're proud to announce another industry first for the Volkswagen and Audi tuning market from Forge Motorsport!
Many owners of any VAG vehicle equipped with the all new 2.0T FSI engine, have unfortunately discovered, that the OEM electronically controlled bypass valves, which bolts directly to the compressor cover of the turbocharger, have their limitations. If you are running increased boost pressures, after a software remap (chip), or the OEM valve is being subjected to high temperatures, the lifespan of the unit is significantly reduced. Even without any modifications taking place to the vehicle at all, this OEM valve has been shown to fail over time and it's boost holding capacity also leaves some room for improvement.
We now have the world's first fully engineered solution offering both significantly improved reliability as well as valve related boost response. Our valve and installation kit replaces the original unit with a pressure/vacuum operated piston valve that still also retains the desirable OEM ECU control over valve actuation. This product has been thoroughly designed and tested with the expressed intent of offering improved valve response and maintaining ECU control while resulting in absolutely NO fault codes, NO check engine lights, and no adverse effects of any kind. All of the necessary components and detailed instructions are included and everything is designed to make installation as simple as possible.
This product is applicable for all of the following 2.0 FSiT applications:
VW Golf MK5 GTI/Jetta GLI, VW Eos, VW Passat (B6)
Audi A3, Audi TT Audi A4 (B7)
SEAT Leon
Skoda Octavia
For all vehicles where the OEM valve is mounted remotely (8P Audi S3, MK5 Golf Edition 30 and the Seat Leon Cupra), please see product reference FMFSITVR.
Old Aug 17, 2008 | 04:49 PM
co_pa's Avatar
biggity bump
Old Aug 25, 2008 | 12:21 PM
New Member
Default Re: *** Forge Motorsport Replacement Vacuum Operated Piston Diverter Valve for VAG 2.0 FSiT ***
bump
Old Sep 17, 2008 | 07:26 PM
New Member
bump
Old Oct 29, 2008 | 04:11 PM
New Member
bump
Old Nov 3, 2008 | 10:17 AM
New Member
bump
Old Nov 27, 2008 | 07:45 PM
New Member
<b>ON SALE!!</b>
Old Jan 13, 2009 | 11:34 AM
New Member
Default Re: biggity bump
bump
Parts4Euro.com
Audi A3 / S3 / RS 3
20
Feb 11, 2009 11:57 AM
Parts4Euro.com
TT (Mk2) Discussion
Feb 11, 2009 11:55 AM
NAMotorsports
Mar 3, 2008 03:37 PM
