2007 A4 6mt boost/timing issues
My b7 A4 6mt, 204k kms, apr stage1 91/93 octane, afe cai, p3 gauge. It has been lacking significant power the day I bought it, almost as if there’s no boost, things I have replaced are, hpfp, lpfp, maf, map, pcv, tb, thermostat, temp sensor, cam follower for hpfp, n75, spark plugs, car has 0 faults. I’ve checked for boost leaks about 6 times in the last 2 months, and have found none, wastegate has 0 play, car burns just under a litre of oil in 7k kms, based on obd11 and the p3 gauge, the throttle is closing at wot, goes from 99.4 to 47 as soon as I get into boost, based on some logs, it’s pulling anywhere from 4-12 degrees of timing, I don’t hear any knock when I’m wot though, I believe the ecu is pulling everything back as a safety and I just can’t seem to figure out why, actual boost meets requested boost, lambda reads .8ish at wot, fuel trims are fine at idle, but partial (block 32-2) shows +23 when driving, lpfp is 4.7bar at idle and wot, duty cycle is 53% at idle and almost 80% at wot around 6k rpm, here’s what baffles me and I’m not sure if it’s due to the throttle angle closing at wot but I can’t get any maf reading higher then 103g/s at 6500 rpm, it’s about 2.8g/s at idle, fuel rail is 50bar at idle and have seen it as high as 120bar at redline. Obd11 shows up to 1800mbar of boost at about 5500 rpm, but my p3 gauge has never seen over 7psi, fluctuates between 3.5-7psi. I have switched back to stock map with 94 octane and same thing even slower with lower boost request. Apr was of no help when I reached out to them and didn’t reply when I sent them some logs. I have a couple saved logs that I would like to post of someone could tell me how, any help/advice would be greatly appreciated.
