A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
code p0171 leaking vacuum pump
Old Apr 11, 2019 | 06:59 AM
tjsilva's Avatar
Default code p0171 leaking vacuum pump
Could the cause of my P0171 code be a leaking vacuum pump? 2006 a4 2.0t. any idea where i should start. I did a tune up this weekend replaced fuel filter, air filter, plugs, and coil packs need to chase down pesky code. I didn't think those would fix the problem but figured it was time . Any help would be greatly appreciated code comes and goes.
Old Apr 16, 2019 | 04:47 AM
zee7's Avatar
Hi,
P0171 - System too lean in bank 1
Meaning there is more air supply than fuel to the engine.This will fluctuate gas mileage. There will be hesitation in engine/acceleration.
1) Replace Upstream Oxygen sensor (Lambda sensor/Air-fuel ratio sensor) if no changes then check for vaccum leaks usually leaks from worn out hoses or loose gas cap
if that doesn't fix then its going to be hectic job next
2) Bad high pressure fuel pump
3) Intake manifold cleaning & gasket replacement
3) Bad fuel injectors (if black smoke coming out from tails)
Hope it helps!
Old Jul 31, 2019 | 05:02 AM
Chachboi's Avatar
With a scan tool clear your codes then drive about 50 to 100 miles as gently as you can. If the check engine light stays off then drive it hard (in sport mode) and get the pedal to the floor a couple times, if it kicks on from that you're most likely being starved of fuel. it will most likely be your low pressure fuel pump (inside the tank). Hpfp and vacuum leaks tend to be most present at idle. I chased this code by replacing the vacuum pump, diverter valve, various vacuum lines, fuel filter, and hpfp before this.
Old Aug 23, 2019 | 10:03 AM
yuvalw123's Avatar
look at the purge valve , its easy and cheap repair.
Michael Felt
Feb 4, 2019 02:20 PM
dmaclaren
Aug 20, 2018 11:29 AM
selfproclaimedv8buff
Audi Original "S" Cars
May 13, 2008 07:54 PM
gtreng1
Oct 1, 2007 11:26 AM
SkinFlaps
Sep 14, 2007 07:06 AM
