A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Engine issues post accident
Old Mar 1, 2020 | 12:35 PM
acarpenter's Avatar
Default Engine issues post accident - VCDS data added
Trying to help my brother in law out remotely. His son has a 2006 A4 2.0t and he ended up on his side in a ditch. BIL has no intention of buying the kid a new car, but he’s willing to help him get this one running again (if possible). At first it wouldn’t start at all and I feared maybe it jumped timing or the belt broke. He confirm it would turn with a wrench on crank, and was able to view timing marks and he said it seems correct. Then, amazingly he got it started. Not sure what he did as he’s in another state. Anyway, it was smoking a good amount and I can’t tell for sure but it sounding like it was misfiring, however it didn’t throw a CEL. He thought perhaps oil just leaked into the cylinders while on it’s side or something. So he ran it a bit to burn it off then replaced the spark plugs. But now it won’t start again. It throws code p0600 which is kind of a all encompassing code from what I can tell. My ideas are maybe it DID jump timing ever so slightly, or maybe burning that oil clogged a sensor and it refuses to start.
Anyone have other ideas?
File Type: mov
Old Mar 1, 2020 | 08:52 PM
Geomeo's Avatar
might want to pull plugs out and connect the thread to a ground using a jumper cable or something like that. Check all the spark plugs are sparking when the engine is turned over. Could be some bad coil packs. That p0600 code.. has there been any module changed at some point? Anything at all in its past life?
Old Mar 22, 2020 | 10:23 AM
acarpenter's Avatar
Crazy quarantine junk has gotten in the way of him being able to do much. Still has that p0600 code. He’s not aware of any modules changed, but they haven’t owned it too long.
He did test compression and is good there, has fuel. The one coil he tested he got no spark so I’m wondering if the computer is not allowing spark for some reason. Bad coils should be unrelated to that code, right?
Old Mar 22, 2020 | 10:56 AM
acarpenter's Avatar
He just tested all coils and no spark... weird that he had it started, though running rough, and now won’t spark and that code.
Old Mar 25, 2020 | 05:29 PM
acarpenter's Avatar
Finally some VCDS data:
Wednesday,25,March,2020,16:01:58:33376
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
VCDS Version 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: WAUDF68E95A478984 License Plate:
Mileage: 205930km-127958mi Repair Order: bricyna4
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUDF68E95A478984 Mileage: 205930km-127958miles
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 A HW: 09L 927 156
Component: AG6 09L 2,0TFSI USA 0030
Revision: --H01--- Serial number: 0089293
Coding: 0000002
Shop #: WSC 06335 000 00000
VCID: 2517F75B79E9202F9A3-8071
2 Faults Found:
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 205934 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 8.0°C
T.B. Angle: 60.0°
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 205934 km
Time Indication: 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004528
VCID: 270BFD5303E5323FA8F-8073
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 50
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4222
Hex Value: 0x00FF
Hex Value: 0xFF97
Hex Value: 0x00FF
01314 - Engine Control Module
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 25
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0722
Hex Value: 0x00FF
Hex Value: 0xFF91
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6C81C27FDF93D16705D-513D
2 Faults Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul USA 0303
Coding: 01023
Shop #: WSC 65536
VCID: 392F2B2BE041B4CFCEB-4B01
1 Fault Found:
01494 - Bulb for Parking Lamps; Left (M1)
30-00 - Open or Short to Plus
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 E
Component: SDAR XM 0080
VCID: 2B0301631A2D165F4C7-5067
1 Fault Found:
02635 - Tuner Not Enabled/Activated
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N000869C
Coding: 0032607
VCID: 3C21323FEA6381E7D5D-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Serial number: 6332DRB400B3511BF
Coding: 00032607
Subsystem 2 - Serial number: 6342DRB400B28928O
Subsystem 3 - Serial number: 6352ARB400459A40E
Subsystem 4 - Serial number: 6362ARB400458EC8Y
Subsystem 5 - Serial number: 63729RB400468353C
Subsystem 6 - Serial number: 63829RB400468646I
2 Faults Found:
01211 - Belt Tensioner Igniter; Rear Driver Side (N196)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Time Indication: 0
01794 - Control Module - Incorrect Chassis (VIN) Number
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 99
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02041
Shop #: WSC 06335
VCID: 41DF43CB8891EC0F86B-4B01
No fault code found.
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 N HW: 8E0 920 981 N
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 02345 444 54467
VCID: 38292E2FDE4BADC7315-5185
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
004 - No Signal/Communication
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
3 Faults Found:
01304 - Radio
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71BFD30BF8813C8F36B-4B3D
2 Faults Found:
07-10 - Signal too Low - Intermittent
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3132
Coding: 11836
Shop #: WSC 06335
VCID: 04518ADFD7033927EDD-4B01
Subsystem 1 - Part No: 8E1959801F
Component: Tõrsteuer.FS BRM 0305
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
7 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
00892 - Switch for Trunk Closing Cylinder (F248)
27-10 - Implausible Signal - Intermittent
01799 - Switch for Interior Locking; Rear Middle (E286); Unlock
00955 - Key 1
35-10 - - - Intermittent
00532 - Supply Voltage B+
37-10 - Faulty - Intermittent
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 20209 444 58908
VCID: 2615F05704EF2B37939-8073
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 39
Reset counter: 40
Time Indication: 0
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0470
Coding: 01205
Shop #: WSC 20209
VCID: 2C01027F1F23116745D-5067
End----------(Elapsed Time: 05:03, VBatt start/end: 12.1V/12.1V)-----------
Old Mar 26, 2020 | 06:35 AM
Geomeo's Avatar
Too many codes. You need to clear them try to start the engine again and rescan. I’m assuming most of these issues have been fixed like airbags etc etc. the immobilizer is triggering like nobody’s business. To add put the sparks back in. We will assume the coil packs are working since no misfires have been detected.
Old Mar 26, 2020 | 11:20 AM
acarpenter's Avatar
thanks-
He cleared out the codes and tried a start after re-syncing his key to the car.
These are the codes afterward. He plans to pull and test the ecu relay today.
Thursday,26,March,2020,13:14:47:33376
www.Ross-Tech.com
Mileage: 205930km-127958mi Repair Order: post-start1
67 69 75 76 77
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 205934 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 12.0°C
T.B. Angle: 60.0°
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 205934 km
Time Indication: 0
Coding: 0004528
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x00FF
Hex Value: 0xFF93
Hex Value: 0x00FF
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x00FF
Hex Value: 0xFF92
Hex Value: 0x00FF
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Coding: 01023
Shop #: WSC 65536
1 Fault Found:
1 Fault Found:
35-00 - -
Coding: 0032607
Coding: 00032607
Coding: 02041
Shop #: WSC 06335
Coding: 0023261
1 Fault Found:
Coding: 0023261
1 Fault Found:
Coding: 00002
Shop #: WSC 00000
Coding: 11836
Shop #: WSC 06335
Coding: 0000019
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Coding: 01205
Shop #: WSC 20209
End----(Elapsed Time: 04:53, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Old Mar 26, 2020 | 12:25 PM
Geomeo's Avatar
do you have a wiring diagram? Can you check the ecu for power? You’re on the right track.
 Michael S. Palmer
Old Apr 4, 2020 | 08:23 AM
acarpenter's Avatar
thanks- I’ll ask if he has found a wiring diagram. He ended up buying a used ecu and still has no communication... so I’m assuming a wiring issue is all that remains. Maybe something for pinched in the accident/flip onto its side.
Old Apr 4, 2020 | 10:43 AM
Geomeo's Avatar
What type of ecu is it? Can you upload the part #? A used one will allow communication, vag obd etc, but unless it has immo defeat in it, it will not work properly. So once you get communication with the used one put the original back in.. Power to the ecu seems likely fault.
