A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
HELP!! Problem!!!
Old Jan 30, 2008 | 01:30 PM
NYCETITSLINE's Avatar
Default HELP!! Problem!!!
<center><img src="http://pictureposter.audiworld.com/136237/100_1683.jpg"></center><p>I posted a few months back about a problem I was having with My A4 2.0 fsi.
I have only REVO stage 1 in the car right now and am still experiencing a problem.
2nd, 3rd, 4th, and 5th gear from 4,000 - redline,
the boost drops significantly from 15psi and then starts bouncing up and down between 10 and 15 psi, till revved out
Been back to the dealer 3 times in 2 weeks with and without the REVO.
They can't figure it out.
Any Audi techs or other people experiencing this? Any Dealers in the NYC area hip to this?
Please help!
ANY input is greatly appriciated.
The REVO is presently set at the performance 2 setting, but I have tried just about every combination I found in these posts.
I have taken the intake and Forge DV out of the car and still NO change.
The only time it doesn't do it is when it is in stock mode and...well...that just don't work for me!
Old Jan 30, 2008 | 01:35 PM
Tgr_Clw's Avatar
AudiWorld Uber User
Any codes?
Old Jan 30, 2008 | 01:43 PM
Default Re: Any codes?
The ever present low rail pressure.
I mentioned to them about the HP fuel pump problem but the say I have the "H" fuel pump.
I'm looking at the paper work from the last time and it says the changed a transfer pump, thrust sensor and cleaned some other sensor.
Old Jan 30, 2008 | 03:43 PM
quattrothatcould's Avatar
Default Try bringing it to KMD in NNJ if you still can't figure it out
They're a reputable shop and a REVO dealer.
Nice looking car btw
Old Jan 30, 2008 | 04:39 PM
Tomasz@Startup's Avatar
Default VAG-COM and log it.
Your Revo dealer should help you a bit. Does this happen with Revo at low boost - stock like boost setting?
Old Jan 30, 2008 | 08:05 PM
artinmoTTion's Avatar
Default perhaps you're maxing out the fuel pump with the chip program, and not with the stock.
it's hard to blame it on the car if it's fine in stock mode. perhaps investigate the apr fuel pump?
Old Jan 30, 2008 | 09:31 PM
r1de's Avatar
Default stock suspension?
I have S-line (Ti) package as well, but your ride height looks a tad lower than mine.
Old Jan 31, 2008 | 07:06 PM
addìct's Avatar
Member
Default log actual vs. requested boost and report back
any codes?
 Michael S. Palmer
Old Feb 6, 2008 | 01:24 PM
Default Re: HELP!! Problem!!!
<center><img src="http://pictureposter.audiworld.com/136237/100_1240.jpg"></center><p>OK! so what's the trick to get the dealer to even look at this HP pump?
It has been back 4 times and they never even checked it.
Supposedly they changed the Transfer pump, thrust sensor, bypass valve, and removed and inspected numerous other components.
I had a discussion with the service manager today and he told me that since it doesn't happen in stock mode, there is nothing he can do.
SO..." If you want something done right, you gotta do it yourself".
Does anyone know what to look for? Should the cam lobe be measured with a mic, and if so what should the lobe measure?
I don't mind getting an APR pump, if that's what it is, but I read in these posts that it is the cam that goes bad and I don't want to get into a head job on this car.
ANY suggestions???
Old Feb 6, 2008 | 01:26 PM
Default Re: stock suspension?
EIBACH Springs
