A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Help with vag codes...
Old Oct 7, 2011 | 05:11 PM
primetime's Avatar
Default Help with vag codes...
Got the following on the A4... any ideas? thanks Ron
1 Fault Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 5
Mileage: 98930 km
Time Indication: 0
Freeze Frame:
RPM: 770 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 52.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.716 V
Old Oct 7, 2011 | 05:22 PM
jiggysmb's Avatar
I think this site is more a spam, reseller site so you will have better luck getting info from Ross tech's site.
Here's what I found.
Possible Causes
Injectors leak/blocked
Air Intake Leak (after MAF)
Exhaust Leak
Possible Solutions
Check Mass Air Flow Sensor (G70)
Check Injector(s)
Check Fuel Pump
Check Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
Old Oct 10, 2011 | 04:37 AM
primetime's Avatar
Possible Causes
Exhaust Leak
Possible Solutions
Check Injector(s)
Check Fuel Pump
Thanks... I cleared it and it hasn't come back yet...
Old Oct 11, 2011 | 03:15 AM
audi01a6's Avatar
RON
what engine do u have 1.8,or 2.
Old Oct 14, 2011 | 10:34 AM
primetime's Avatar
Originally Posted by audi01a6
RON
2.0T in the A4... CEL still hasn't come back and the car runs fine... Any reason you ask? Any insight is appreicated... thanks Ron
Senadye0
Q5/SQ5 MKI (8R) Discussion
Jul 29, 2016 05:41 AM
Barry in Utah
Sep 24, 2008 12:48 PM
mtbracer
9
May 11, 2004 05:51 AM
ChrisTTiaan
Jul 15, 2002 09:07 AM
albino_mocha
Feb 17, 2002 07:16 PM
