A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Low injection quantity .. injector problem ???
Old May 21, 2023 | 07:16 AM
Beany1's Avatar
Default Low injection quantity .. injector problem ???
Hi injection quantity is bouncing around 1.5 and 2.5 mg it supoossed to be around 3.0 to 9.0 mg what could be the problem all 4 injectors are reading within range audi a4 b7 2.0 tdi 2006 thanks
Old May 22, 2023 | 03:37 AM
Hayabusafalcon's Avatar
Bad fuel pump or pumps. Clogged fuel filter.
Old May 22, 2023 | 05:24 AM
Beany1's Avatar
Hi its got new fuel filter a month ago from dealers had new intank fuel pump too can a remap sort this out can the vacuum pump cause this issue too thanks
Old May 22, 2023 | 05:43 AM
Umm, I'd be skeptical of that fuel filter!
Edit See this:https://www.audiworld.com/forums/a4-...light-3042204/
Old May 22, 2023 | 06:03 AM
Beany1's Avatar
Is there fuel filter no good its from audi paid 41 pound for it the car drives spot on no smoke anything only when engine gets upto operating temperature it starts vibrating and shaking at idle only and its underfueling by looking at the data
Old May 22, 2023 | 06:06 AM
Beany1's Avatar
Old May 22, 2023 | 07:27 AM
Beany1's Avatar
I been looking on forums and people say you can set IQ higher as mine is low ( injection quantity )
Old May 22, 2023 | 09:13 AM
Is it the correct filter?. Verify.
 Pouria Savadkouei
 Michael S. Palmer
Old May 22, 2023 | 09:21 AM
Beany1's Avatar
Well it is the correct filter as i gave them plate number and the right fitting
Old May 23, 2023 | 09:48 AM
Beany: I mentioned fuel filter since you said it had been replaced. Often when new issues crop up it's after something has been done to the car. I would not ignore the fuel filter issue. Run that to ground. Also, I did not note this before but what about that fuel pump? It that the correct pump? Afternarket? Verify that is or is not the problem too.
I'm always skeptical when work has been done on the car and then a new problem shows itself. I always go back and look/verify. Is it the new part or parts that's the problem? It is plausible for a new part to be bad out of the box.
The conditions you noted sound to me like a fuel-starved condition.
If no then an intake air restriction of some type.
Let us know what you find.
All the best, Haya....
