Not going into gear when starting
I just have one question, when you remove the slave cylinder, how close is the fork to the bell housing is it right up to the window or is there a slight gap?
I have no leaks no nothing when the engine is switched off it slides into gear easily soon as I start the car the gear stick won't let me select anything, that said when the engine off an the car is starting In gear the car moves and let's you change gear fine.
Any help or guidance it'll be greatly appreciated.
