A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
problem with central locking after using VCDS
Old Oct 31, 2021 | 08:31 AM
rio's Avatar
rio
Default problem with central locking after using VCDS
I have a 2005 audi a4 avant and wanted to have the windows open and close via remote, all worked fine BUT if I press the remote the doors won’t lock until I press the lock/unlock button on the drivers door whilst the ignition is in stage 2 any ideas so I can fix it, only the car keeps losing battery power unless I do this
Old Oct 31, 2021 | 08:36 AM
rio's Avatar
rio
I don't have the problem after pressing the switch all works as it should but if you forget to press the interior switch the fob won't work and you can't lock the doors and the alarm won't arm
Old Oct 31, 2021 | 11:06 AM
A4Audi4Fun's Avatar
Haven't heard that symptom before - I suggest you disable everything to do with window open/close with the remote and enable remote lock /unlock of just the driver's door. Confirm that works and that a 2nd click unlocks the other doors; check that the remote unlock button works for opening the boot; then reenable the remote window open/close. Hopefully that will help you identify which part of the car locking process is not working correctly.
Old Nov 1, 2021 | 06:56 AM
rio's Avatar
rio
many thanks for getting back to me, I ve to recheck I ticked the right must have ticked a box in vcds when doing the doors I will have to check I ticked the right boxes many thanks again trial and error
branshew
Jun 5, 2006 09:00 AM
Mr. Malcontent
Audi 100 / A6 (C4 Platform)
Dec 23, 2005 08:30 PM
spdracer53
Feb 25, 2005 12:41 PM
Illusive90S
Dec 28, 2003 05:25 PM
jcurry
Nov 24, 2003 01:39 AM
