A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Reverse lights help
Old Jun 6, 2022 | 10:09 AM
Phasleyt's Avatar
Default Reverse lights help
3.2 Dsg reverse light are not working, dash says “right reversing light” back checked and changed, fuse checked any idea what next?
Old Jun 6, 2022 | 10:56 AM
Hayabusafalcon's Avatar
Phas....Likely the reverse switch. You will need to research its location (I have no 3.2 nor dsg). Most likely on the transmission shift linkage under the hood . A common issue with VAG vehicles. Good luck, Haya
Old Jun 6, 2022 | 10:57 AM
Phasleyt's Avatar
I keep seeing things about it but can’t find any pictures or exact details, seems to be a common problem but not many answers to it 😢
Old Jun 6, 2022 | 11:05 AM
Check down there where the shift linkage meets the trans. Use a good light.
Have someone shift it into reverse and out again as you look..
Old Jun 6, 2022 | 11:15 AM
Phasleyt's Avatar
Looks alike a fun job for the weekend
Old Jun 7, 2022 | 12:26 PM
A4Audi4Fun's Avatar
Bending the tag at the base of the bulb upwards might also help get better contact with the bulb. Overtime a little arcing and reduced spring pressure can cause intermittent or no contact.
Old Jun 7, 2022 | 01:47 PM
Phasleyt's Avatar
Yeah tried that, it’s the live wire going to it but somewhere between the Dsg box and the bulb holder or the Dsg stalk itself, turning into a nightmare
janl
Jan 24, 2014 03:48 AM
S-Line Q5
Q5/SQ5 MKI (8R) Discussion
Jan 17, 2014 03:39 PM
igotonee
Aug 31, 2013 05:13 AM
Stew0104
Dec 25, 2009 01:40 PM
