A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Rough running
Old Jan 29, 2008 | 06:53 AM
Hogplt's Avatar
New Member
Default Rough running
I've an '07 with low miles and experienced problems wice in two daysin COLD Minnesota weather. The engine ran real rough, the following lights were illuminated: EPC, traction control, check engine, and low oil pressure. Dealer said ice buildup in drain valve caused it and nothing they can do about it. Anyone else have this problem or can you suggest anything? Thanks.
Old Jan 29, 2008 | 07:28 AM
Tgr_Clw's Avatar
AudiWorld Uber User
Low oil pressure huh? Sounds exciting.
Old Jan 29, 2008 | 05:47 PM
mpucher's Avatar
Default Drive it really hard and long
and get it really hot. Will help to get any moisture out of the oil to help prevent freezing.
Old Jan 30, 2008 | 09:59 AM
Hogplt's Avatar
New Member
Default Re: Drive it really hard and long
Thanks, I appreciate the suggestion, but 20 minutes to work. The second time I had the problem, I'd driven for 40 minutes. How much driving is necessary? I do not believe that the moisture should build up. Owned Mercedes and BMW with same driving habits and never a problem. Had the oil changed, but that does not address the problem of moisture buildup in the first place.
Old Jan 30, 2008 | 02:47 PM
B_S373N's Avatar
heh heh heh. hard, long, hot, moisture, oil....heh heh heh.
Old Feb 2, 2008 | 12:06 PM
mpucher's Avatar
Default Found a TSB for ya
There is a new TSB (#2017076/1) that I found regarding your issue. Audi calls for a new oil pump pickup strainer and to make sure the software is the latest and greatest (the same as the I3 update). Hope this helps.
townbiscuit
A6 (C7 Platform) Discussion
18
Apr 7, 2026 08:44 AM
Garyha4b8
A4 (B8 Platform) Discussion
84
Dec 9, 2025 03:48 PM
Hogplt
2.0T FSI Discussion
Jan 29, 2008 09:23 AM
feelstranger
Apr 29, 2005 04:34 AM
maTTi
Jun 21, 2003 01:04 PM
