Stuttering Engine On Acceleration. Please help!
The car runs fine other than that but I can barely accelerate aggressively at all without it doing this so takes the fun out of it a bit. Could there be any thing else that would cause this? And only once when I kept accelerating and it kept stuttering did the check engine light come on, since then I don't do it.
Please help! Thanks in advance to everyone. If you have any questions I'll be quick to reply.
Took it in, there was excessive wear on the cam follower, so they replaced the cam follower and cam shaft and whatever else is in there. All under warranty.
Take it in.
Take it in.
Added Text 24 May 2011
Click here for confirmation of extended warranty by 06 2.0T on May 24: https://www.audiworld.com/forums/sho....php?t=2792882
If your cam follower is worn and replaced with no other damages, the cost is about $250-$300. If there is significant damage to other parts costs can balloon up to $2000-$3000. But before panic sets in, I suggest you read up on the latest news, contact your Audi dealer for the latest on the cam follower issue, and finally bring it in to see what the extent of the problem is.
Good Luck on this.
