A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Uneven tire wear
Old Feb 5, 2007 | 03:03 PM
ABL2point0t's Avatar
Default Uneven tire wear
I took off the left side tires on my S-line quattro this weekend and noticed severe and uneven tire wear on the rears. I have taken my car in for service at the dealer and they never mentioned anything about it (they dont even include rotation at the 15k service). I just hit 17k today and the rears are pretty much shot. Im taking it in for the dealer to look at it, what are the chances that AOA will pay to replace the 2 tires that are worn out due to the dealer never looking at them? Sorry for the long winded post, I just dont think I should have to buy new tires bec the stealer was negligent.
Old Feb 5, 2007 | 03:19 PM
bhvrdr's Avatar
Default Sucks then. If they dont include rotation than it seems you are expected to take care of it...
and 10K is probably too long to go between rotation on these anyways. Sorry about that. FWIW, 17K miles on a set of max performane tires isnt the worst ive ever seen Next time rotate/flip every 5K or less depending on your driving style. If you do a lot of straight ahead freeway driving you may have to rotate more.
Old Feb 5, 2007 | 03:29 PM
A4 Joe's Avatar
Default I thought we did not need to rotate on a quattro car
I did not on my B5 or B6 and got about 28,000 miles...or did I rotate them...I guess I don't really remember, because in the old days they would rotate under warranty.
Old Feb 5, 2007 | 03:55 PM
98's Avatar
98
Member
Default should rotate front to back not x.
front tires will wear faster than the rears with quattro.
Old Feb 5, 2007 | 04:38 PM
lowdef's Avatar
Senior Member
that only matters if tires are directional.
Old Feb 6, 2007 | 03:25 AM
joeymagl's Avatar
New Member
Little to no chance AOA will pay to replace your tires
Old Feb 6, 2007 | 06:19 AM
at165dB's Avatar
Default Don't wait for the dealer, 15k is prob too long to go w/o rotating, and it's so easy to DIY.
Autozone, hydraulic jack and 2 jack stands = $30. 2 more jack stands are just $15.
buy 5 hockey pucks too, and you are now ready to do some real service to your car.
Rotating your own tires is as easy as it sounds. I own a tread wear guage and take measurements every 5k to make sure ware is even ACROSS each tire (and adjust PSI accordingly), and to note the front to back delta.
I just rotated my tires at 11k by swapping the tire with the most wear for the least ware, and then swapping the remaining two.
Front tires will wear out more becaues they also do your turning, so quattro or not, there is no reason not to rotate to get the most mileage out of your tires.
Also worth mentioning is that less than 3mm of tread, while not minimum tread a tire says you can run on, will drastically increase your stopping in the rain. (there was a 5th gear eppisode on that, but the show sorta sucks now).
Old Feb 6, 2007 | 07:22 AM
Plasticar's Avatar
Default Re: I thought we did not need to rotate on a quattro car
You certainly do have to rotate. The front tires always do more work, as they hold up 60+% of the weight, and get the majority of the side load from turning the car. I do mine every 7500 miles, but you could just as easily do it every 5k around the time of your oil change, especially with high performance tires that wear faster.
Develop a relationship with your local tire shop (Discount / America's Tire, Belle Tire, etc.) They will be cheaper than the dealership, usually quicker, and once you know the guys, they will often throw services in for free or discount (flat repair, balance, good deal on replacements). Consider it advance work for when you buy the next set of tires. It should only cost you about $20-30 per rotation, including balance.
Be sure to have them re-balanced when you rotate, especially if you are cross rotating with non-directional tires. Even with directionals, at half-life, I will have them dismounted and turned around so they can go on the opposite side. Just to help even out the wear.
I can be a sphincter about my tires, but it is the only part of the car that touches the road.
Old Feb 6, 2007 | 09:57 AM
98's Avatar
98
Member
right...I was assuming directional.
Old Feb 6, 2007 | 10:23 AM
initialA4's Avatar
very slim... X2
AlbertQ7
Q7 MKII Discussion
20
Jun 4, 2021 09:10 AM
HunterWagner
Audi A5 / S5 / RS5 (B9)
Apr 21, 2019 11:25 AM
RED HORSE
Apr 18, 2015 07:50 AM
rarslan
Q7 MK 1 Discussion
13
Jul 17, 2013 11:28 AM
ALR
Jul 23, 2002 09:25 AM
