A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
2011 A4 Sport Suspension = Popping Noice Over Bumps
Old Feb 1, 2011 | 01:28 PM
BrilliantBlack's Avatar
Default 2011 A4 Sport Suspension = Popping Noice Over Bumps
Hi Guys,
I just picked up my brand new 2011 A4 2.0T with the Sport Package and I love it. However, I am sensing something peculiar happening with the suspension. When I hit larger bumps/potholes at speeds under 35mph I hear a hollow popping sound which sounds like it's coming from the right rear side. I've read a couple of threads saying that it may be the shippping blocks if they failed to remove them. I think I have ruled that out, since I took a peek back there and dont see anything like that. The second try was taking out the spare tire and unpacking the jack and accessories and repacking them to make it tighter...which did nothing. I'm almost ready to just take the spare, jack, covers etc. out of the trunk just to rule out something bouncing.
Anyone else have this problem? Please let me know, if not I think i'm headed back to the dealer to make them investigate.
Thanks in advance for your help!
Old Feb 1, 2011 | 01:58 PM
gunsmoker's Avatar
Originally Posted by BrilliantBlack
Hi Guys,
I also have a 2011 A4 with the sport suspension. I got it last November. I don't hear the sound you mentioned, but I noticed on the second day that there was a loose yellow rubber thingy on the right rear shock absorber. Looking at the left one, the rubber piece was sitting halfway into the upper tube of the shock.
I jacked up the car and squeezed the loose piece into its tube just like on the left side.
Take a look if yours has the same unfinished work. If that part is loose it can certainly make noise when going over bumps or potholes.
Old Feb 1, 2011 | 09:37 PM
SimpsonTide985's Avatar
We need photos of your car to help expedite any further assistance..
Old Feb 4, 2011 | 01:29 PM
Default Picture of Rear Shock
Just a follow up to this post. I was able to take a picture (sorry for the quality, that was all I could do from my iPhone)of my right rear shock. I don't really know what I'm looking for, but this Yellow rubber looking piece is all i see when looking under the rear fender. I'm pretty sure it's not a shipping block, but if anyone could give me some pointers if this is standard on the Sport Package suspension and if I should start looking elsewhere for my noise.
Thanks in advance for your help guys.
Old Feb 4, 2011 | 03:40 PM
gunsmoker's Avatar
That's exactly what I was talking about. Same thing on my car, same wheel. If you look at the shock of the other rear wheel, you will see that the yellow rubber piece is into the tube above. It has a small lip that keeps it in place. The wheel well is very tight and you will need to lift that side on the jack to get more space and push the yellow thing into place. I used a screw driver to stuff it in and then a plumber's wrench to grab it and push it all the way up while turning. It's a 10 minute job.
The other side of the yellow part holds a tube that protects the shock piston. You can see the piston exposed above the yellow part.
Old Feb 5, 2011 | 03:26 PM
quality_sound's Avatar
That's just the bumpstop and it shouldn't cause any popping noises, even if it's not fully seated in the upper strut mount. Now, if it has a dust shield on it (plastic tube that covers the strut rod) and the bumpstop isn't secured in the upper mount the. It's possible the strut body is hitting the dust shield when the suspension compresses, causing the noise you're hearing.
Old Feb 5, 2011 | 04:31 PM
gunsmoker's Avatar
Yes, there is a dust cover attached to it and it freely goes up and down the strut rod if it's not seated in the upper mount.
Old Feb 6, 2011 | 04:45 AM
ashaffer1903's Avatar
Default fixed!
Thank you gunsmoker, I fixed the car this weekend. It still raises the question of why this was like that in the first place, seems like I shouldn't have to do finish work on a brand new car. But nonetheless, it is fixed! Thanks for all of your help
Old Apr 5, 2011 | 07:13 AM
uberwgn's Avatar
Super Moderator
Guys, did we ever ID this part and what is a-miss? I drove a new car with Sport Pkg a few weeks ago and heard a very distinct noise/knock twice while on the test drive. Almost sounded like something banging in the (right??) rear suspension. Thx.
Old Apr 5, 2011 | 08:21 AM
gunsmoker's Avatar
You now know where to look when you take delivery. See the picture earlier in the thread. The yellow rubber part needs to be firmly planted into the tube above it.
