A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Address book questions
Old Oct 22, 2010 | 12:09 AM
kat.hayes's Avatar
Default Address book questions
1. I read that there is a limit to the number of contacts that can be imported. If it does not import someones contact info because of the limit, can you still give it a voice command to dial a person's name even if it is not imported?
2. Can you access people's addresses for navigation directions based on the addresses imported with your phone?
3. I also read that you can load addresses from a memory card. How does this feature work?
Thanks!
Old Oct 22, 2010 | 12:53 AM
Canuk1.8T's Avatar
Hi Kat,
1. There is a limit but IIRC correctly it's quite high and there are 2 separate limits - one being for the contacts it access via your phone and how many you can download to the hard drive.
2. You can not navigate to a person's address if it's on your phone. You would need to download the contact to the hard drive and then you are able to do this. More below.
3. I copied over vcf files from outlook onto a memory card and imported them to the car. You will now need to access each one separately and click on 'Enter Navigation Address" or something like that. Once you do this MMI will import the address info into a section it can read from. You can now hit the 'back' button on MMI and do the same for the others.
I know it's not 100% intuitive but it doesn't take a long time. The same steps are used when trying to navigate to someone on your phone. MMI will copy said contact to the hard drive, then follow the steps above.
Test one vcf file first to ensure you are getting the info needed into the right spots within the contact card on your computer. It took me 2 tries to get it right.
The owners manual doesn't fully explain the above which I found frustrating at first
Hope this helps.
Perry
Old Oct 22, 2010 | 07:18 AM
eshaheen's Avatar
Where does the memory card plug in?
Originally Posted by Canuk1.8T
Hi Kat,
Hope this helps.
Perry
Old Oct 22, 2010 | 07:41 AM
Canuk1.8T's Avatar
Assuming you have a 2010 with Navigation like mine you hit the Open button on the dash where a flap opens and there you have your CD/DVD player and 2 SD card slots.
P
Old Oct 22, 2010 | 10:27 AM
QUA77R0's Avatar
My '09 Avant has no difficulty accessing/scrolling through my contact list in my phone. I don't import any contacts. It's a google/android phone if that makes any difference. My wife's HTC/windows mobile phone does not access her contacts even though it still connects fine with bluetooth. There is no hard drive on the '09 Bang & Oluffsen stereo that I am aware of.
It would seem a bit backwards that the hard drive that you have would have less capacity than your phone.
Old Aug 22, 2011 | 12:44 PM
JBrownie's Avatar
Can you share the vcard data format that worked for you? I loaded about 80 contacts last night (via SD card) and the address fields are 'all jacked up'.
Also the new MMI (with Audi connect) is supposed to be able to read contacts from your myaudi account but for the life of me I can't figure out how to add a contact via import - I can add a map destination just fine...
IMHO - The MMI manual is 'el stinko' (that's a nice way to say something akin to 'urine poor')
thedjm
S4 (B8 Platform) Discussion
11
Nov 3, 2011 02:04 PM
web.boards
Q5/SQ5 MKI (8R) Discussion
Oct 18, 2010 05:54 AM
stanw
17
Sep 22, 2010 08:09 AM
jakeller
Aug 26, 2009 07:40 AM
dadew
May 6, 2008 08:30 PM
