A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Amplifier replacement
Old Mar 19, 2022 | 07:49 AM
Will_'s Avatar
Default Amplifier replacement
I recently bought a 2013 Audi A4 Avant SE Technik. I'm really happy car with the car so far, but it didn't come with an amplifier. The original unit was faulty, and the man at the garage had tried to get it repaired but no luck, and didn't get the unit back. In short, I'm wondering what model I need to get as there seem to be a few different options out there. Any advice or direction welcome
Old Mar 19, 2022 | 09:19 AM
SMac770's Avatar
Community Builder
Community Influencer
That depends on what equipment you have. Do you have MMI (Multimedia) or Concert in the dash above the climate controls? Do you have the standard or B&O sound system? B&O will have silver rings around the tweeters in the front door sail cards.
Old Mar 19, 2022 | 10:39 AM
Will_'s Avatar
It's MMI, 3G+ I believe. There are no silver rings
Old Mar 19, 2022 | 11:15 AM
SMac770's Avatar
Community Builder
So MMI 3G (would be + being facelift, software version in the screen display should start HN+) with standard sound system would mean you have a single combined radio/amp unit in the left rear. B&O would have a separate radio unit and separate amp unit. Concert would have just an amp unit back there.
Radio/amp unit for that, in US/Canada market with sat radio support, should be 4G0 035 080 G, might also be seen as 4G0 035 082 G. Earlier revisions D and E are superseded, but should work fine. Your car would have come with a D or E originally anyway.
053 units lack the amp and the sat radio. 056 units lack the sat radio. So if really in a corner, you might consider a 4G0 035 056 unit (revisions E > G > J), but I can't say if it would play flawlessly (minus the sat radio) or not.
Keep in mind that whatever you source and install, it's not going to be functional until you take it to the dealership so they can bless your work for one hour labor (to remove component protection). Thank Audi for that.
Old Mar 20, 2022 | 05:31 AM
Will_'s Avatar
Thanks for this - I don't suppose you know if it would be the same part number in Europe (UK). Presumably it would?
Old Mar 20, 2022 | 06:13 AM
SMac770's Avatar
Community Builder
No, that's a US/Canada market with Sirius tuner unit. If you need UK, then it's a question of DAB or no DAB.
Old Mar 20, 2022 | 08:04 AM
Will_'s Avatar
It's a DAB capable vehicle, though I can't say I have much use for the radio personally
Old Mar 20, 2022 | 04:01 PM
SMac770's Avatar
Community Builder
I thought Technik was a Canada trim term. Is it also used in the UK?
Euro is so much more complicated. So MMI 3G over there comes in High (joystick on the big dial) and Basic (no joystick on the big dial); we only have the High option here. You also have the option of the basic sound system (8 speakers, no dash center or rear sub).
So if we presume the standard sound system (10 speakers, with center and sub, no B&O markings) and B8.5 MMI 3G:
3G Basic with DAB: 4G0 035 061 D > H > K > M > P
3G High+ with DAB: 4G0 035 061 E > J > L > N > Q
3G Basic w/o DAB:4G0 035 056 D > F > H
3G High+ w/o DAB: 4G0 035 056 E > G > J
So as noted before, a number of revisions over the years, but any of them should work fine, though they might need firmware updates, and will need component protection removal. Not really sure why the 3G Basic (BNav) and 3G+ High (HN+) need different versions.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 23, 2022 | 06:07 AM
Will_'s Avatar
Yep, used in the Uk too. Thanks for all your help - just have to try and source a somewhat reasonably priced unit now!
RRHMJ23
Jun 14, 2020 04:56 AM
DB2712
A4 (B7 Platform) Discussion
Mar 6, 2017 09:26 AM
SilberUrS6
Audi Original "S" Cars
Dec 27, 2008 08:23 AM
qfrog Ti20
Jun 11, 2006 02:39 PM
frame2
Mar 22, 2001 08:46 PM
