Auto Leveling Issues
I guess you could go old school and just unscrew the leveling sensor arm from the control arm and move it up and down slightly to see if the headlamps move. Don't loosen the sensor at the bracket or you'll have to rerun the adaptation (ie, VCDS again). Do you see the DRLs move up/down when starting the car? They should move up/down the adjustment range before settling on "level" at start up.
There's also the question of do you have halogen or HID. It sounds like you have HID as you're wondering about the auto-leveling system, but you don't explicitly state it. The halogens have a manual leveling system (**** on dash) iirc, not the auto-leveling system of the HIDs.
Otherwise, you'll just have them on the left side, as that's all the HID auto-leveling system needs. That would be PR code 1BA (standard) or 1BE (sport).
As we see here, https://nemigaparts.com/cat_spares/e...q/636u/941250/, the part number for the rear level sensor is different for 1BL vs 1BA/1BE.
309F for left rear for 1BA/1BE, 309D for left rear for 1BL, 310C for right rear for 1BL. Is there anything actually different between 309F and 309D? No idea.
You apparently have the ADS controls so chances are high that you have adaptive suspension, but ADS is added as soon as one of the options that "needs" ADS is added, like Dynamic Steering.
