Auto switch to reverse camera
I recently retrofitted a OEM RVC and everything is working correctly except for having to select the camera every time i select reverse. By default it goes to the Park Assist screen.
Is there a way to change the default screen to the camera. It is a 2015 Avant.
Then I would suspect that there is some coding missing. I have the factory installed camera and it starts in Rear View mode (with the vertical graphics overlay in the picture).
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525PA8-J3890QT
Coding: 1031006
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DG HW: 8K0 907 063 DG
Component: BCM1 1.0 H16 0103
Revision: 07016001 Serial number: 00001106047301
Coding: 260000118034AFE01481400000001D0D4F9D07082709020100 000800440003010000002C000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Revision: --H04--- Serial number: 525PA8-J07924A
Coding: 1020007
If i change byte 7 bit 0 to 0 (Parking aid installed)i get the rearview camera but no parking aid overlay, change it back to 1 and that is when it defaults to the parking aid with "Rear View" in the bottom left corner.
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 670 K HW: 8R2 035 670 J
Component: H-BNT-EU H50 0941
Revision: -------- Serial number: 517GZ0F7504206
Coding: 0F0101010006E3EF05809B5E00000403040000000000000000
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Revision: 08016001 Serial number: 00000053843001
Coding: 2600C0118034AFF03981408300001D0D0F9CE3082609020100 0008004400070100000034000000
Part No SW: 8R1 035 666 J HW: 8R1 035 666 C
Component: H-BN-EU H46 0941
Revision: -------- Serial number: 205J80D7878825
Coding: 0F0100000006A3EF0580AB5E00000403E40000020000000000
All working as it should. Now my hair can grow back. See below
With VCDS go to Controller 09 Central Electrics, then Long Coding, Long Coding Helper.
Select Byte 35 and tick bit 4. If bit 4 is not available as it was on mine, select "LCode2" on the top menu which should allow you to select Bit 4. This will change the HEX value to 34. Once Coded you need to go into the Parking Sensor Menu on the MMi, then disable Display and then re-enable the display (This is very important!)
The Reverse Camera will now be the default when reverse is selected and the OPC display will show on the right side over the camera image.
Make sure 6C is ticked in CAN gateway Installation list.
Make sure 5F is coded for byte 7, bit 1. Reboot MMI. Make sure 6C is coded correctly.
