A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Broken Upper Overflow Hose Replacement
Old Aug 26, 2023 | 08:00 AM
regularcat193's Avatar
Default Broken Upper Overflow Hose Replacement
2014 A4 Quattro.
Long story short, the upper overflow hose from the radiator to the expansion tank has broken at the quick connect on the radiator. The nipple that inserts into the radiator from the hose snapped in half. I'm trying to get the remaining piece out of the radiator flange but I'm struggling. Is it possible to clean it up to the point no small pieces can become free into the coolant and then use a basic coolant hose instead of the factory hose I've purchased? I'd like to use a basic hose to fit over both the radiator and expansion tank flanges fastened in place with hose clamps. Any advice or information on this is appreciated or if someone has a fool proof way of removing the broken insert allowing for the new factory hose to be used I'd be grateful. Thanks in advance.
Old Nov 9, 2024 | 02:31 PM
Datbomb's Avatar
Did you ever get this fixed? I'm in the exact same problem. I can't get the bridge nipple/stem out from within the upper radiator plug
Old Nov 9, 2024 | 04:49 PM
Datbomb's Avatar
In case anyone else runs into this issue I used a drill. Start with a smaller drill bit and work up to a bigger drill bit. Start picking off the shavings with a need nose plier. Go slowly. Eventually you'll be able to pull all of it out.
Old Mar 28, 2025 | 11:10 AM
ElectricSmith's Avatar
Originally Posted by regularcat193
2014 A4 Quattro.
Did you only drill part of it? There’s a keyway at the end that makes it so you can’t turn it. That’s what’s stopping me from drilling it right now
Old Mar 29, 2025 | 08:14 AM
142 guy's Avatar
I would be more inclined to use a small easy out / screw extractor to pull the remains out. If you have a tap and die set you could also use an appropriately sized tap tap to pull the remains out.
Old Mar 29, 2025 | 11:46 AM
The problem is the connection is keyed so you can’t turn it. That’s how they usually break is you try to turn it.
I was able to get it out with a drill. Kept going up in sizes until it eventually cracked into 2 pieces and I got the rest out with a pick and vacuum.
nbaj805
Jan 23, 2023 06:18 AM
m1964
Q5/SQ5 MKI (8R) Discussion
May 11, 2021 07:32 PM
m1964
May 11, 2021 09:36 AM
a6wrenchin
10
Oct 14, 2015 07:10 PM
blacka41p8turbo
Oct 30, 2005 09:56 AM
