A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
codes
Old Jan 29, 2018 | 01:34 PM
Alfonso Bernard's Avatar
Default codes
2013 Audi A6 Quattro Sedan (4GS) L4-2.0L Turbo (CAEB)
Started with a small fender bender and the left headlight assembly stop working, the right still works normally. I swap the right to left for a fast quick check to verify if the light modules was okay. Now the right is not working. Codes are 01516, 00927, 02258 not find specific for these codes.
Old Jul 9, 2018 | 08:43 PM
officer120's Avatar
I have the same code 02258, I believe its the comfort control module which needs to be reprogramed.
Old Jul 10, 2018 | 08:48 AM
SMac770's Avatar
Community Builder
Community Influencer
Google search by code number brought up each relevant ross-tech page.
So you have two codes related to Terminal 30. It mentions a possible problem with exterior lights and to check the J519 supply voltage. You'll want to check the fuses in the battery jump box (in the center of the plenum chamber, under the hood in front of the wipers). Terminal 30 also supplies the radiator fans; are those working?
The 02258 is related to the home link transmitter.
So I assume you have some broken circuits or blown fuses that have yet to be repaired. That you swapped headlamp assemblies and the problem followed the assembly means it's broken and will need to be replaced (maybe just ballast, maybe bulb and ballast).
But it would be nice to have "the rest of the story" on those DTCs. There should be a subcode that gives more direction, like: 02258 - Door Opener Transmitter / 004 - No Signal/Communication
mkanakis
Q7 MK 1 Discussion
Oct 5, 2018 06:29 AM
audiblackwagon
12v V6 Discussion
Nov 19, 2007 04:41 AM
JDeL
Oct 12, 2006 05:06 PM
imaudi5
Misc. Models Discussion
Oct 9, 2000 01:30 PM
