A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
engine oil level
Old Aug 1, 2012 | 04:10 AM
dreamcar2012's Avatar
Default engine oil level
should i be concerned? if so, do i bring it to the dealer or just any mechanic can fill it up?
Old Aug 1, 2012 | 04:16 AM
Turbo Freak's Avatar
25 Year Member
It is missing about a quart.
You can fill it up yourself, it is very easy !
Old Aug 1, 2012 | 04:37 AM
What do i buy, and how do i do it....i am totally new to Audis
Thanks!
Old Aug 1, 2012 | 06:10 AM
rdA4WtQ5's Avatar
If you put in (1) quart with that gauge reading the next thing the display would say is "Please drain oil".
I would only put in a half quart to avoid that.
Old Aug 1, 2012 | 08:02 AM
dk1's Avatar
dk1
Thanks!
Here is what I personally do:
Go to the dealer and buy a couple of quarts of oil (my car goes through 1 quart in 2000 miles but YMMW). When the car is 1 quart low a yellow warning will appear on the dashboard with a message "You can continue driving but add 1 quart of oil". At that point you can add exactly 1 quart without any guesswork and the monitor will go back to full.
All of 2.0T engines seem to burn oil, which sucks. Unless the consumption is excessive (0.5 quarts in 600 miles) there is not much you can or should do.
Old Aug 1, 2012 | 08:28 AM
Sounds like a great idea! thanks! so i can still drive around with what is in it right now, and not get in trouble?
Old Aug 1, 2012 | 09:05 AM
25 Year Member
One would hope that you would go in steps and not pour the whole quart all at once !
Old Aug 1, 2012 | 09:32 AM
dk1's Avatar
dk1
Yes but buy the oil now because it might not be too long before you get the warning. Think of the electronic display as if it were the marked area on a dipstick. If the oil mark is in the area you are OK, if it's below you add 1 quart.
Old Aug 1, 2012 | 09:43 AM
ALLDATAdiy INFO's Avatar
Former Vendor
Alldatadiy.com has all maintenance schedule and specifications as far as type, capacity and how to. Good Luck!
Old Aug 1, 2012 | 10:24 AM
Thanks again, I will go to the dealer soon, I just picked up my audi about a week and a half ago and i'm writing down things i want the dealer to take a look at (i didn't buy it at an audi dealer)and because it still under warranty i want it all corrected before the warranty runs out. the sunroof squeaks when i open it, the steering wheel shakes a little at low speeds (like in a parking lot). Also, I will see if I can get a new crankcase pressure-regulating valve to solve the oil consumption issue that will be nice....not bad for a gal that didn't know anything about Audis before i bought this one huh......
