.:Eurocode Tuning:. Introducing our FMIC kit for the B8 A4 2.0TSI
Our FMIC kit features the following:
• 22" x 11" x 3" high density bar and plate core
• CAD designed cast aluminum endtanks, with directional vanes on the hotside to reduce turbulence
• CNC machined, billet aluminum support bracket, engraved with our logo
• CNC machined, billet aluminum 2.5” turbo outlet adapter
• Mandrel bent, 2.5” aluminum hard piping from turbo outlet, to core and from core to throttle body
• CNC machined, billet aluminum MAP sensor bung
• 5 ply silicone couplers (six provided)
• 316 stainless steel t-bolt clamps (twelve provided)
• 316 stainless steel installation hardware (all inclusive)
• Plumbing available mirror polished or satin black powder coated
Both form and function are equally important to the team at Eurocode, because of this; we set out to build the most beautiful and top performing kit on the market. Computer aided design (CAD) and Stereolithography (SLA) was used throughout our modeling process. Computational fluid dynamic (CFD) software provided us with the calculations to develop a cast aluminum endtank that is so efficient, the pressure drop and turbulence are among the most minimal we have seen. This efficiency has proven to reduce air intake temperatures (IATs) by as much as 35% in repeated full load runs. Reduction of IATs is crucial to performance of turbocharged engines; we have seen horsepower recovery in excess of 20WHP due to heat soak with APR stage II programming. Temperature recovery of our FMIC is incredible as well, allowing for stable IAT’s during multiple full load pulls.
The team at Eurocode found that the tiny 2” cast aluminum turbo outlet flange was a huge restriction to turbo output as well as spool time, because of this; we are including a 2.5” (over 60% larger) CNC machined billet aluminum outlet adapter. This adapter provides a smooth transition to our 2.5” mandrel bent aluminum hard piping.
Aesthetical highlights of our FMIC kit are the gorgeous CNC machined, billet aluminum support bracket, which allows the core to be suspended in free air from the factory crash bar. The brace is attached with rubber well nuts that provide both ease of installation and vibration dampening. Our 26” wide core (endtank to endtank) fills if the entire lower portion of the grill. Installation is a breeze with absolutely no cutting, trimming or welding.
$1495.00 plus shipping, please click here if you would like to place an order.
