A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Fault Code 01496
Old Jan 23, 2018 | 06:21 PM
JoA4Sline's Avatar
Default Fault Code 01496
Does anyone know why, upon me removing my ugly yellow fog light bulbs and inserting [stunning] Sirius 30W 6000K Super Bright White LEDs, my car threw a Fault Code 01496? Would this be an issue of the vehicle requiring a load resistor because these things are too bright? OR is this an issue of someone at Audi didn't "Sign off" on a product from Sirius? The other more technical question I suppose is without a MIL being thrown I assume this is definitely not an issue that needs to be addressed today right? Still if I drive around with these in the fog light housing, will the wiring harness somehow get fried or like will they burn out prematurely because of their brightness and the load resistor is a method to reduce current flowing to them but potentially making them less appealing to look at?
Old Jan 23, 2018 | 09:25 PM
SMac770's Avatar
Community Builder
Community Influencer
01496 just means something with the left fog light bulb. You need the rest of the DTC code that says the actual problem.
From another VWVortex thread that had the same code, notice two instance of the same code, but different data, reflecting different issues.
2 Faults Found:
01496 - Bulb for Fog-Lamps; Left (L22)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 4
Fault Frequency: 28
Reset counter: 73
Mileage: 20150 km
Time Indication: 0
Date: 2013.14.03
Time: 17:44:55
Freeze Frame:
Term 15 On
Voltage: 14.20 V
ON
ON
OFF
OFF
ON
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 73
Mileage: 20820 km
Time Indication: 0
Date: 2013.14.16
Time: 13:16:03
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
Old Jan 24, 2018 | 04:09 AM
jagtoes's Avatar
Try putting the old bulb back in and clear the code. If it doesn't code again then the new bulb will not work in the car. A resister will just make the new bulb dimmer.
Old Jan 24, 2018 | 06:26 PM
JoA4Sline's Avatar
So both bulbs work [look] great and I can see the road a fair bit better. I didn't have to time research the code further but will use my Carista app to do so.
Okay here it is: Part #: 8K0907063DH
Coding is [man what a long number] 26000096863CAFc00000480300003D0D0F1C53082209020100 0008004400030100000020000000 (hex)
Component: BCM1 1.0
Old Jan 24, 2018 | 06:33 PM
JoA4Sline's Avatar
Would Carista or OBD11 be able to decodE?
Old Jan 24, 2018 | 06:37 PM
jagtoes's Avatar
So if you didn't want to remove the new bulbs and replace the old bulbs you can't determine if the new bulbs are causing the problem. Based on this you'll have to find others who will advise you .
Old Apr 21, 2018 | 05:35 AM
RA090224's Avatar
Banned
Default Using Carista i got the same fault error on both bulbs
Central electronics
Part #: 8K0907063DH
Coding: 26000017863CAFE00700488300003D0D4F9CC7082209020100 0008004400030100000034000000 (hex)
Component: BCM1 1.0
Fault codes:
01500 Bulb for Fog-Lamps, Right (L23)
01496 Bulb for Fog-Lamps, Left (L22)
How can I fix this knowing that both bulbs are working fine. Should i just rest from Carista or whats your advice?
Old Apr 22, 2018 | 04:25 AM
SMac770's Avatar
Community Builder
You need more info, like what I posted above. So there's some issue from the BCM's perspective regarding both headlights, but you're missing the rest of the DTC data to say what the actual problem is.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 22, 2018 | 10:47 AM
RA090224's Avatar
Banned
how would i get this extra information? This is what the app provided. From the dash board I don’t get any warnings or faults.
Old Apr 22, 2018 | 06:16 PM
SMac770's Avatar
Community Builder
With these modern cars, they know far more than the manufacturers will ever let them tell their owner. Remember, you're not Audi's customer, the dealership is.
If you're going to troubleshoot your own Audi, the normal tool to have is Ross-Tech VCDS (ross-tech.com). There's another tool that was referenced around here too, that runs on phones/tablets (maybe it was Carista you mentioned). I use VCDS.
Looking into Carista, maybe that was the one some talked about here. I think it used to have a Pro price point that included what I would consider basic functionality. Looks like the pricing model has changed, now you pay $40/year to get the real tool. The paid version should be able to pull the complete DTC data.
anm2p2015
Audi A3 / S3 / RS 3
Oct 10, 2022 09:28 AM
SiMpLyMoDiFiEd
Dec 23, 2016 11:58 PM
c-dub
Q5/SQ5 MKI (8R) Discussion
18
Oct 8, 2011 09:49 AM
nbvolks
Feb 11, 2008 06:03 AM
mj12b
Oct 14, 2004 05:13 PM
