A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Fuel: Low pressure code
Old Aug 5, 2024 | 11:10 AM
2013Audia4's Avatar
Default Fuel: Low pressure code
I was on a road trip (about 350 miles) and on the way there the car did great, But on the way back the car threw a CEL and 7 different codes. One was for a low fuel pressure. I also noted that the car was getting terrible gas mileage. The other codes was stating that there was a random misfire on each cylinder. Any thoughts on what It could be? I took the back seat off and when you first start the car you can hear a little bit of a shine coke from the in tank pump. I saw a thread saying to try and replace the fuel filter on the pump before the pump so I am going to try that first. Any input welcome and appreciated. Thank you!
Old Aug 9, 2024 | 07:11 PM
SMac770's Avatar
Community Builder
Community Influencer
So you're working with a list of seven codes. But we are not working with that list of seven specific error codes, so we can't say what we would do in response to the codes we don't have.
You don't provide any specifics about the vehicle either. But if we make the assumption that the vehicle in question is the same as the vehicle in your username, you might want to inspect the terminal pins on the fuel pump flange (you'll need to remove it to see the underside) for burns. And the fuel filter is not a separate object in a B8.5.
Breyden Phillips
S4 (B8 Platform) Discussion
Mar 5, 2022 05:16 PM
Mike_k
Feb 28, 2022 10:29 AM
Tiffany Brown
Mar 12, 2019 05:53 AM
AudiRacer94
A4 (B7 Platform) Discussion
Apr 14, 2018 10:09 AM
SkinFlaps
Sep 14, 2007 07:06 AM
