A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Headlights
Old Jun 5, 2019 | 04:25 PM
RRHMJ23's Avatar
Default Headlights
I've had the dreaded light malfunction light on my dash since I bought my car, took it to Audi and they said they couldn't figure it out. Today I took both lights out of my car passenger side LED DRL bulb plug broken and the plug was melted . I'm guessing that was the problem. I've a new plug and bulbs. My question is why doesn't the DRL/ sidemarker bulb have a removable dust boot on it like the other bulbs ? It looked like they were sealed in the housing and the previous owner made a access hole then siliconed it up. Does anyone sell a custom boot for these two holes?
Old Jun 6, 2019 | 06:28 AM
SMac770's Avatar
Community Builder
Community Influencer
I assume you have the low end halogen headlamps? Since the bixenon use the LED DRL. You also don't mention the year, as B8.0 and B8.5 are different.
Assuming B8.0, https://nemigaparts.com/cat_spares/e...q/636u/941000/
So what exactly on that diagram are you asking about?
Old Jun 6, 2019 | 06:50 AM
RRHMJ23's Avatar
My car is a b8. The part number on the actual assembly is 8k0941003B and 004B.
Old Jun 6, 2019 | 10:26 AM
SMac770's Avatar
Community Builder
Curious. Guessing the 003B (left) / 004B (right) are just the numbers stamped on the housing piece, but you can't get the housing piece alone from Audi. parts.audiusa.com doesn't even know know 8k0 941 003b / 004b. So from an ordering perspective, it's 029b and 030b part numbers. Though you might find reference to the 003b and 004b part numbers in the used market. Such as https://www.ebay.com/itm/09-10-11-12...-/173597798335
It sounds like maybe you're referring to this:
11 - Parking Lamp/Daytime Running Lamp Housing Cover
❑ The headlamp must be cut open to replace the bulb.
❑ A housing cover can be ordered to seal the headlamp opening. Refer to the parts catalog.
4 - Turn Signal Housing Cap
❑ The cap can be ordered to seal the headlamp opening. Refer to the parts catalog.
14 - Parking Lamp/Daytime Running Lamp Housing Cover
❑ The housing cover can be ordered to seal the headlamp opening. Refer to the parts catalog.
So the caps are ordered to cover the bulb location once the original blown bulb has been cut out?
So that would be parts 2, 3, and 18 on the page I linked you originally, I would suspect.
Old Jun 6, 2019 | 12:15 PM
RRHMJ23's Avatar
That's exactly what I was looking for. Thank you
YHL
Mar 4, 2001 06:10 PM
A4by4
Mar 4, 2001 12:35 PM
Boba Fett
Oct 2, 2000 09:42 AM
