Tyre Pressures - weird recommendation in manual
In the owners manual is says :
"The tyre pressure must be adjusted according to the load the vehicle is carrying. We recommend adhering to the tyre pressure specifications for a maximum load. The tyre inflation pressures are listed on a sticker on the end face of the driver's door Fig. 1.
However, if you prefer an extra-smooth ride and the vehicle is not fully loaded, you can select the tyre pressure for a normal load (no more than three people travelling in the vehicle). However, should you wish to drive with a full load you must increase the tyre pressure to the specified maximum."
So they're recommending the harder pressure regardless of whether you're loaded or not.
I've never heard of this before. What are your thoughts? My guy instinct is that this is the same as running over inflated tyres but they say it's not.
I'm puzzled
I'm puzzled
I'm puzzled
I'm puzzled
I think they are simply trying to protect themselves against liability. AFAIK, new cars in the U.S. now come with a single pressure recommendation because our government thinks some drivers are just too stupid to be trusted with the proper selection. This happened after the Ford Explorer low tire pressure fiasco you may have heard about.
If I drove my Passat with the full load and over 100+ mph tire recommendation, the tires would feel grossly over-inflated and the ride would be ridiculously punishing. I know because I once loaded about 900lbs worth of tiles in the trunk and had to inflate the tires to the maximum recommended pressure. After unloading the tiles, the over-inflation was quite evident.
Now as to whether or not some drivers are too stupid.......
Scottyuk : The '09 US manual does not have such a statement -- the closest thing I see is :
"If you wish to improve comfort when operating the vehicle at normal load (up to 3 occupants) you can adjust the tire pressure to those specified for the normal vehicle load. Before operating the vehicle at maximum load, you must increase the tire pressure to those specified for maximum vehicle load"
I do remember vividly all the hoopla about this roughly four years ago. Perhaps not being a sizzling issue anymore, VW/Audi feels safe in circumventing the rule a little. Again, it would be great if you could report the door jam sticker pressure.
I am not quite sure, but I think the single pressure recommendation might have been only for the door jam sticker. If you get a chance, can you take a look at it?
Many thanks for the info.
Maybe they thought that those who actually bother taking a look at the manual will be likely to pay enough attention to understand the extra info correctly
tire pressures
don
