Long Block Engine code, Engine Serial Number
The long block that I bought from Audi is missing the SN on engine block, did anyone else bought long block that can check if VW writes SN on engine blocks used to build long engine block, all I have is front sticker on valve cover showing the engine code and SN. But the SN on engine block looks like it was removed or never laser printed.
https://www.ebay.com/itm/17520400821...Bk9SR-r4--iKYw
VEHICLE MAKE: 2014 AUDIMODEL: A4 WAUHFAFLXEN011104.
ENGINE: 2.0L TURBO TRANSMISSION: AWD MANUAL
"I believe that is the engine's serial number but the same long block can fit the needs for multiple engines codes in multiple markets for multiple vehicles. The part number you bought might fit ten engine codes worldwide. In that case no engine code marking makes the most sense.
In some markets the same basic turbocharged engine can be sold with more than one HP or PS output as limited by parts or software other than the long block. For VW it is cost effective to make as few replacement parts numbers as possible to keep costs down. Again, because cheaper to do it that way."
