A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Long crank to start + multiple error codes
Old Mar 12, 2021 | 01:23 AM
Ridjuan98's Avatar
Default Long crank to start + multiple error codes
Hi guys hope all is well. I purchase an Audi A4 1.8TFSI Multitronic 2010 yesterday and it struggled to start, was told it was just the battery but now after driving and plugging my OBDII in I think otherwise. Here is a video of me starting my car:
And Here below are the error codes that came up, which one do you think could most likely be the cause of this and how much would it set me back? The car drives absolutely perfectly it doesn’t run rich or lean and no lost of power etc. Just difficult to start
Car Scanner ELM OBD2
DTC report
Selected brand: Volkswagen
VIN: WAUZZZ8K9AA170390
============1==============
P0016
Raw code: 0016
ECU: Engine control unit
Status: Confirmed
OBDII: Crankshaft position/camshaft position, bank 1 sensor A - correlation
============2==============
3041
Raw code: 0BE1
ECU: 19. CAN Gateway[Archive (inactive)]
Status: Validated and stored in non volatile memory
Volkswagen: Energy management active
============3==============
1317
Raw code: 0525
Status: Test conditions are met, Validated and stored in non volatile memory
Volkswagen: The control unit in the instrument cluster-J285; Control Module in Instrument Cluster (J285); Control unit in dash panel insert-J285
============4==============
2248
Raw code: 0008C8
ECU: 02. Transmission control unit
Status: Pending, Confirmed, Test failed since last DTC clear
Volkswagen: Control valve responsible for the degree of opening of the coupling-N373; Valve for controlling the degree of opening clutch-N373
============5==============
0446
Raw code: 01BE
ECU: 03. ABS control unit
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory
Volkswagen: Work restriction due to insufficient voltage; Functional restriction due to undervoltage
============6==============
4629
Raw code: 001215
ECU: 01. Engine control unit[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
Volkswagen: Injection valve cylinder 3-N32 Short circuit to positive
============7==============
4735
Raw code: 00127F
Status: Test failed since last DTC clear
============8==============
4096
Raw code: 001000
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
Volkswagen: Injector cylinder 9-N299 electrical fault in the circuit
============9==============
1330
Raw code: 0532
ECU: 05. Authorization system for access and starting the engine
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory
Volkswagen: Comfort Central Control Unit-J393; Central control unit for convenience system-J393; Pressure sensor for air conditioning-G65 signal too small
============10==============
0457
Raw code: 01C9
ECU: 08. Heater and climate
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: On-board power supply control unit-J519; On-board power supply control unit J519
============11==============
0256
Raw code: 0100
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: Refrigerant Pressure and Temperature Sensor-G395; Refrigerant pressure / temperature sender-G395; Air mass meter-G70 supply voltage
============12==============
1187
Raw code: 04A3
Status: Pending fault present, Validated and stored in non volatile memory, Validated fault present at time of request
Volkswagen: Air Temperature Actuator Rear Actuator-V137; Servomotor for rear temperature flap-V137
============13==============
1206
Raw code: 04B6
Volkswagen: No ignition moment signal; Signal for ignition off period
============14==============
0457
Raw code: 01C9
ECU: 10. Parking Assistant 2
============15==============
0446
Raw code: 01BE
ECU: 16. Steering column
============16==============
0532
Raw code: 0214
Volkswagen: Supply voltage
============17==============
0446
Raw code: 01BE
ECU: 42. Driver door electronic equipment[Archive (inactive)]
============18==============
0532
Raw code: 0214
============19==============
1317
Raw code: 0525
ECU: 46. Central comfort systems module (VW TP2.0)
Status: Test conditions are met, Test has not been completed, Validated and stored in non volatile memory
============20==============
0532
Raw code: 0214
============21==============
0457
Raw code: 01C9
============22==============
0532
Raw code: 0214
ECU: 47. Acoustic system
============23==============
0446
Raw code: 01BE
ECU: 52. Front passenger door electronics[Archive (inactive)]
============24==============
0532
Raw code: 0214
============25==============
0446
Raw code: 01BE
ECU: 56. Head unit (MMI) (VW TP2.0)
============26==============
3157
Raw code: 0C55
ECU: 56. Head unit (MMI) (VW TP2.0)[Archive (inactive)]
============27==============
0532
Raw code: 0214
Old May 21, 2021 | 03:37 PM
Brett Carney's Avatar
Hey guys i have a code p 201500 com8ng up 8n my audi a4 b8 8k 2008 tfsi 1.8 liter i took my car to the machenic and he said something along of the lines of your car will never fail if u can handle the check engine light on i have replaced all fuses i have cleanned throttle body and all sensors i am worried i am going to do damage to my manifoild,i done the maf test and my car kept running when i pulled the sensor off but i did get all codes indicating that its working.i am new to audi and would appriciate anyones help..
Old May 22, 2021 | 05:15 PM
rocketman4321's Avatar
Default Taking a guess..
With all those codes from different controllers, likely they're either old or you had a low-voltage condition (like trying to start for a long time with a weak battery). I'd try to clear them (the ones you can, anyway), and see if they come back. Your scanner should at least be able to clear the engine ones. If the battery seems fine after a drive, but is weak, say, the next morning, they it's likely going bad. It's also possible that the alternator is intermittent--works at high speed/highway and not at idle or stop-and-go. Check the battery voltage--should be ideally 12.6 V, but modern cars may be a bit less. With the engine idling, ideally it's close to 14V, but again modern cars cut out the alternator if charging isn't needed. And check/clean the battery terminals thought I doubt that's the issue--but it's an added burden on a weak battery.
If the battery is 3-4 years old, you may just want to replace it as a first step.
Old May 22, 2021 | 05:46 PM
Hey thank you for ur reply there 8s nothing wrong wirong with my battery putting out 13volts..
Old May 22, 2021 | 05:48 PM
Ive ordered a new gas cap and im going see if it gets r8d of light and maybe p201500 at the same time or im 8n for a new manifoild
Robscoe
A4 (B7 Platform) Discussion
Jun 15, 2021 02:19 PM
Robscoe
Jan 19, 2021 04:27 PM
VeeT22
Dec 11, 2020 08:34 AM
slowpoke
Audi allroad
Oct 13, 2008 07:29 PM
KramS4
VAG-COM Discussion
Oct 13, 2006 12:15 AM
