A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
NEED HELP!!!!!!!
Old Jan 16, 2021 | 10:50 PM
Leandry's Avatar
Default NEED HELP!!!!!!!
I own a b8 audi a4 [ 2010 ] codes:P2015 and P2279, it all started when I step on the gas and the car lost power and started having multiples missfires I tried giving it less throttle and everything seemed fine then when I tried stepping on the gas all the way did the same thing, missifres and saw my check engine light flashing does not know what that means, I replace the throttle and went better but after a minute it started shaking and the idling was terrible, took the sparkplugs out they were burn *** hell replace them put NGK sparkplugs, still having the same problem shaking engine and missfire on all cylinders can anyone please help me fix this problem I'll appreciated 🙏.
Old Jan 17, 2021 | 02:43 AM
SMac770's Avatar
Community Builder
Community Influencer
What is "replace the throttle" supposed to mean? And "went better"? What went better? Feel free to compose your posts using complete sentences.
Any search for P2015 and Audi B8 A4 should have turned up the most common cause of that issue on our vehicle, the intake manifold. Have you checked that? Likely the issue since you have a simultaneous P2279 (lean, i.e. excess air ingestion).
Further searching should have turned up that ECS sells a "cap" you can use to hold the swivel post into the manifold to correct the issue, assuming that is your issue.
https://www.ecstuning.com/b-ecs-part...021071ecs01~a/
$60 is less than the cost of a new intake manifold, but I made my own bracket from spare pieces. You just need something to keep that post pushed in until you finally get a new intake manifold.
Awrekz
12v V6 Discussion
Nov 30, 2010 08:21 AM
audi901988
17
Jun 5, 2010 06:51 PM
NOLA TT
10
Jan 11, 2008 10:04 AM
Kingate
Jul 18, 2005 10:11 AM
SinChar
Mar 3, 2002 02:47 PM
