A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Is this normal?
Old Feb 26, 2020 | 10:40 AM
Pjinca's Avatar
Default Is this normal?
We have a 2016 A4 quattro premium plus. It has 37k miles on it. Yesterday it started sputtering and nearly stalling a couple of times at red lights. The check engine light cane on. I took it to autozone to check the codes. The only thing that came up was the oxygen sensor for bank 1 (before the catalytic converter). It still being a fairly new car without a ridiculous amount of mileage, is it normal for these O2 sensors to fail?
Old Feb 26, 2020 | 10:41 AM
uberwgn's Avatar
Super Moderator
Not normal but electronics and sensors can always act up unexpectedly. Is this car under warranty?
Old Feb 26, 2020 | 10:59 AM
SMac770's Avatar
Community Builder
Community Influencer
"something with the words oxygen sensor bank 1" is not a code. And there's usually more to the error than just a code number, and that "more" tends to be important. My only experience with trying to die when I came to a stop was when I had a crack in the intake tubing (old Ford Probe). I was having to shift to N at lights to keep it from dying. Once I found the crack in a corrugated flex part of the intake path and replaced it, all good again. I wouldn't say an intake leak or O2 sensor failure at that mileage would be normal. But someone has to be the extremes of the statistics. You didn't say anything about misfire codes; seems fine running but idles rough (I wouldn't say nearing stalling though, just idling rough) is often the PCV. Now that is a part that is pretty common to fail on these engines.
But as noted, if the car's in-service date is after Feb 2016, you're still under warranty. Just have the dealership fix it.
Old Feb 26, 2020 | 04:24 PM
Pjinca's Avatar
Correct, the only codes throwing the CEL were for the O2 sensor, no misfires, not other errors at all. And since the problem of shaking and nearly stalling doesnt happen at every stop light makes me think it could just be the O2 sensor. Misfires, when they happen, are not intermittent. Same thing with a crack in the intake somewhere
culi
A6 (C7 Platform) Discussion
Mar 7, 2016 06:48 AM
AlexRM
Mar 25, 2004 03:33 AM
S4Patrick
28
Feb 5, 2004 11:17 AM
GreenBean
Jan 26, 2004 02:55 PM
N2AK
Audi 100 / A6 (C4 Platform)
Feb 24, 2002 05:41 PM
