A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Oil burn = replace pistons
Old Sep 23, 2010 | 04:44 PM
  #11
TurtleLakeA6's Avatar
Originally Posted by MrStuff
-Bad luck
-The way you broke it in
-Bad part
or a combination of all the above?
2010 2.0T
I am not the original owner, but seeing as the previous owner was a 60 yr. old lawyer, I highly suspect he was not negligent during the break in period.
I purchased this at a non Audi dealer, but I am requesting Audi "certify" the car and provide the certified warranty as a commitment to the car and workmanship from this point forward.
Old Sep 27, 2010 | 05:52 AM
  #12
MrStuff's Avatar
I feel you, I would be a bit more confident if someone older (then younger) owned the car before. You also don't need to be negligent, you just might not know the "you shouldn't dos".
Anything "break-in" would be tough to "certify"... I'm unsure how you would certify proper break-in. Blackstone oil analysis maybe? (anything less time and $ consuming other then tearing down the engine)
Old Oct 1, 2010 | 10:48 AM
  #13
Got the car back.
Audi added 2 yrs of factory warranty. i'm amazed.
Old Oct 1, 2010 | 11:04 AM
  #14
QUA77R0's Avatar
Nice to hear that you were well taken care of after the repair. Too often I think people don't give the dealers/manufacturers any credit when they step up to the plate but are quick to Cast aspersions at them when there is an issue they feel was handled poorly. Nice to hear that someone else is actually having a good experience with Audi ownership even if there are hiccups along the way.
Old Oct 1, 2010 | 02:40 PM
  #15
Yes, however, this was after Audi sent the car home with me a couple days ago without properly connecting the radiator and subsequently causing the car to lose all its coolant. Had to tow it back to the dealer.
This made the added warranty a little easier to attain.
Old Oct 1, 2010 | 07:18 PM
  #16
mart242's Avatar
Got the car back.
Ah, that's why my stuff ended up flying away in the house. The earth stopped turning.
Old Oct 2, 2010 | 12:20 AM
  #17
QUA77R0's Avatar
Sounds like one of those hiccups to which I was referring.
BTW, when looking up TSB's on our Audi the other day, I did notice a coolant TSB relating to coolant leaking (possibly loose fittings) but I believe it concerned the coolant leaking out onto the turbo housing.
Old Dec 1, 2011 | 01:22 PM
  #18
LoveMyA42009's Avatar
Default Burning oil - now replacing pistons +rings
Exactly same thing as TurtleLake happening to my car, AUDI A4 2009 2.0. For two years, the dealers were saying, "it's normal" to keep adding oil. I was replacing a quart every thousand miles. Now, after having tested the oil consumption, the dealer will replace the pistons and rings. Here is my question, why doesn't AUDI acknowledge their problem that a new expensive car needs an engine repair after only three years in service and only 35,000 miles of very gentle suburban driving?
My question to the Forum folks - what can I expect as a downside of having the engine repaired and re-assembled on a new car like this? Resale value? I wonder what else can go wrong?
Thanks!
2009 B8 2.0T
Burning 1qt/ 1000 miles.
Audi says this is excessive after oil consumption test.
AoA tells dealer to tear down the engine. They find the pistons and rings were out of spec.
Result = replacing pistons and rings. Should have the car back next week.
This is concerning since the pistons probably came from the factory out of spec. That means there are more 2.0T's with bad pistons.
Just an FYI
Old Dec 1, 2011 | 03:37 PM
  #19
FSures's Avatar
My car flunked the oil consumption test. Audi is re-ringing the car. Nice to get the engine freshened up after 45,000 miles. Just wondering if anyone has questioned what the excessive oil consumption will do to the cat.
Old Dec 3, 2011 | 11:38 AM
  #20
JNRB2009's Avatar
Default Similar problem
2009 B8 2.0T 65,000 miles, original owner
Car started burning more than 1qt every 1,000 miles. Out of warantee. I did a proper break in when new and have been changing the oil every 5,000 - 7,000 Using Motul Specific 5W40. Called Audi dealer who told me there was a fix. They performed the following, no charge, the invoice says "Good Will":
Test Drive
J Separator
Screw
Seal
Perform Oil Consumption Test
Pressure Realease Value Remove+Reinstall
Crankshaft Oil Seal, Pulley End, Remove and Reinstall
Perform ECM Update
Lock Carrier Lossen+Fasten
I got car back. Oil topped up to max. Reset trip odometer to zero. 4 days and 235 miles later I justed checked the oil level in the MMI. It's down 1/4. So it looks like the "fix" was a no fix. I was really hoping the problem was solved. I really love the car and was planning on running it many years. I will call Audi to see what are next steps. This is a real bummer and a significant issue with an otherwise great car.
Anyone else have the same "fix" performed with no results? What do you all think next steps might be? I am going to remain hopeful. I have purchased 3 Audis. My dealership seems to care about good customer service.
