P2015 code
Thanks,
Tom
Plus, if the P2015 is coming and going, had that before it finally broke open like yours also did. There was no drive issue, and it only showed up after several hours of Interstate steady cruising. But, you should log the data and get a view on the actual going on before deciding it's worth ignoring.
You might have carbon build up interfering with the movement of the flaps. I checked mine lately and noticed the arm moved fine, but it wasn't what I would call smooth, and had a bit of "crunch" noise in the motion.
