A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
These are the codes, any help is greatly appreciated!
Old Feb 22, 2013 | 11:56 AM
blwestwood's Avatar
Default These are the codes, any help is greatly appreciated!
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Friday,22,February,2013,13:53:16:52523
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 65 72 77
VIN: WAULF78K69N029347
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 0104010A190F0160
Shop #: WSC 09112 444 195015
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F93C5AF81479D0662
5 Faults Found:
4698 - Function Restriction due to Received Malfunction Value
U1113 00 [109] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 77422 km
Date: 2013.02.15
Time: 11:51:59
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [039] - De-Energized Performance Too Early
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
5664 - Mass Air Flow Sensor (G70)
P0100 00 [237] - Supply Voltage
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 77422 km
Date: 2013.02.15
Time: 11:51:59
2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 00 [104] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77425 km
Date: 2013.02.15
Time: 12:01:34
4000 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 00 [109] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 77422 km
Date: 2013.02.15
Time: 11:52:00
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0030
Revision: --H04---
Coding: 001002
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 3663F766898A56A8CB0
1 Fault Found:
2505 - Torque Management Feedback Signal A
P2637 00 [044] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77422 km
Date: 2013.02.15
Time: 11:52:02
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 150500
Shop #: WSC 02399 823 56573
VCID: 79F93C5AF01479D0662
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 14
Reset counter: 183
Mileage: 77422 km
Time Indication: 0
Date: 2013.02.15
Time: 11:51:59
Freeze Frame:
Hex Value: 0x1100
Hex Value: 0x4002
Hex Value: 0x1209
Hex Value: 0x46A3
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 183
Mileage: 77422 km
Time Indication: 0
Date: 2013.02.15
Time: 11:51:59
Freeze Frame:
Hex Value: 0x1400
Hex Value: 0x6202
Hex Value: 0x1213
Hex Value: 0x02A4
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0141
Revision: 00002001
Coding: 090100
VCID: 3365CE7292F84380ECE
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0107.09.081494
Coding: 64002000
VCID: 70EF017EA36E3898D1C
2 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 10
Reset counter: 222
Mileage: 75694 km
Time Indication: 0
Date: 2013.01.09
Time: 12:15:50
Freeze Frame:
Voltage: 13.50 V
Temperature: 20.0°C
Temperature: 10.0°C
Count: 11222
Count: 11619
Bin. Bits: 00000000
Bin. Bits: 00000111
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 183
Mileage: 77426 km
Time Indication: 0
Date: 2008.05.27
Time: 00:06:10
Old Feb 23, 2013 | 12:34 PM
Moviela's Avatar
Looks like every code except P1956 (Fuzzy Dice Missing From Mirror.)
If your car is under warranty. Let Audi sort it out. If not, because the check engine light is on, you may have an emmission warranty to cover it.
Did you car go through a hurricane or get flooded? Water up over the engine? If not, good. Lets see what the total picture looks like.
It is mostly sensors reporting incorrect data. This could mean you have a long list of bad sensors, or more likely a problem with the voltage running the modules.
A flat battery, loose connections on the terminals at the battery, or at the distribution point where you attach the charger. The fat cable from the engine to the chassis loose or bad. A bad alternator, voltage regulator, bad serpentine belt, or tensioning device. If the belt slips, the alternator can't produce enough current.
Next, a module that is not sleeping when the car is off, draining the battery, corrosion on the connectors of the modules, or even animals knawing the wiring.
Beyond that you need to do pinpoint tests on each device that is crying for help.
Old Feb 23, 2013 | 06:24 PM
blwestwood's Avatar
Hey there,
Thanks for the response, I really appreciate it. I'm thinking that maybe it's all having to do with the power for the ecm so that is the first thing I will check. A little info; the car has not had any water damage. The clip on the MAF broke and dropped down, burning on the exhaust. I'm not sure if this caused enough heat to the pins inside the plug to cause damage to the wires or not. Do you happen to know the procedure for pinning out the ecm. I would say I am mechanically inclined but don't know much about electrical components. If you could tell me exactly what I need as far as the best testing tool and the 123...etc. process I would greatly appreciate it. Thanks you so much!
Old Feb 23, 2013 | 06:28 PM
blwestwood's Avatar
Also, what are the chances that it's just the power supply relay?
Old Feb 24, 2013 | 04:35 AM
jagtoes's Avatar
Originally Posted by blwestwood
Hey there,
It always helps to get more info. I would assume that the MAF shorted out which would start a chain reaction to various other sensors. Do we assume you repaired it and plugged it back in and cleared all of the codes? After doing this then do we assume all of these codes came back? Does the car run? Are all of the fuses check and replaced if necessary? If all has been checked and you still get these codes I would be suspicious of the ECU being damaged.
Old Feb 25, 2013 | 10:45 AM
blwestwood's Avatar
Unfortunately I have not received all the parts I need in order to fix MAF plug. I should get everything by Tues or Wed. I thought if I cleared the codes even with the MAF out of commission it may still work? I guess this is wishful thinking. Does the car need to read the maf after having a short? I'm hoping that this is all it is and I can start it right up after replacing the plug.
Old Feb 25, 2013 | 12:26 PM
jagtoes's Avatar
Do a little reading here http://www.ask.com/wiki/Mass_flow_sensor and you'll see how it affects the ECM. You will continue to trigger sensors until you fix/replace the MAF issue.
Old Feb 25, 2013 | 04:56 PM
blwestwood's Avatar
Good info, thanks!
Old Feb 27, 2013 | 06:47 PM
blwestwood's Avatar
Hello, I am still getting these codes. I am hoping that it might just be the relay? I don't know...
Wednesday,27,February,2013,20:39:00:52523
Chassis Type: 8T0
VIN: WAULF78K69N029347 Mileage: 77430km/48112miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
Revision: E1H14---
Readiness: 1110 0101
Revision: --H04---
Coding: 001002
Coding: 150500
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 77436 km
Time Indication: 0
Date: 2008.05.27
Time: 00:45:54
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0009
Hex Value: 0x46A3
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 183
Mileage: 77436 km
Time Indication: 0
Date: 2008.05.27
Time: 00:45:54
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0013
Hex Value: 0x02A3
Hex Value: 0x00FF
Revision: 00002001
Coding: 090100
Coding: 64002000
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 77436 km
Time Indication: 0
Date: 2008.05.27
Time: 00:08:43
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000226212
Coding: 690000B1063C00010000080300007F5F0F1452080000000100 0000
VCID: 306FC17E63EE789891C
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 160908 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 F HW: 8K0 941 531 F
Component: E1 - LDS H07 0070
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Component: AirbagVW-AU10 H27 0410
Serial number: 0039KD148FA/
Coding: 303836354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 408F91BEDB4EE81861C
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0800001QUB
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4033470B5
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3F716908N
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME790C0036E
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME00073106
Crash sensor for front airbag; driver side:
Serial number: 63732SME3C0A0E3CA
Crash sensor for front airbag; passenger side:
Serial number: 63832SME230B2908Z
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HIH000B8
Coding: 000014
VCID: 3D71E84AA4BC85F00AA
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DR14EJ98
Coding: 8B1309000300D705020000
VCID: 2D51D80A74DC1570BAA
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G088298224
Coding: 000303
VCID: 468387A6F16AC6285B0
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000007705046
Coding: 011C03204000410001
VCID: 418994BAD844E1106E2
4 Faults Found:
02110 - Window Regulator Switch
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 223
Mileage: 77427 km
Time Indication: 0
Date: 2008.05.27
Time: 00:46:35
00913 - Window Regulator Switch; Front Right Driver (E81)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 77427 km
Time Indication: 0
Date: 2008.05.27
Time: 00:49:15
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 4
Reset counter: 223
Mileage: 77436 km
Time Indication: 0
Date: 2008.05.27
Time: 02:41:48
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 223
Mileage: 77436 km
Time Indication: 0
Date: 2008.06.01
Time: 02:33:17
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0114179640
Coding: 0106063A007A000400B001
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H06 0041
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6ED31F06B95A2E68C30
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000007696782
VCID: 408F91BED34EE81861C
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000215555
Shop #: WSC 00000 000 00000
VCID: 3169C47A68E471909E2
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 183
Mileage: 77436 km
Time Indication: 0
Date: 2008.05.27
Time: 00:48:32
Freeze Frame:
Voltage: 13.20 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1047336
Coding: 05020002010185004119070000
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
4 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 113
Mileage: 75663 km
Time Indication: 0
Date: 2013.01.09
Time: 10:19:44
02244 - Button in Control Head is Stuck
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 109
Reset counter: 183
Mileage: 75664 km
Time Indication: 0
Date: 2013.01.09
Time: 11:00:57
Freeze Frame:
Bin. Bits: 00010000
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 223
Mileage: 77436 km
Time Indication: 0
Date: 2008.06.01
Time: 02:32:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 223
Mileage: 77436 km
Time Indication: 0
Date: 2008.06.01
Time: 02:34:49
End -----------------------------------------------
Old Apr 27, 2021 | 01:23 PM
Aaron Barnes's Avatar
Default Q5
Hi there please can you help as you sound very clued up ..
I have the following faults flagging up immediately after clearing codes
Hello please can any one help with the following ...
Alright the fault codes that keep appearing
U1113 function limitation due to received malfunction valve
P0651 sensor reference voltage b circuit open
P1440 egr vac regulator solenoid valve open circuit
And in the abs module
01314 engine control module
00473 electronic parking brake control module -j540
Any of that make sense to you
Thankyou in advance
markray
VAG-COM Discussion
43
Jun 12, 2016 02:26 PM
tipptop9
Mar 22, 2015 08:23 AM
stroker351w
Jun 20, 2014 10:18 PM
markray
Q7 MK 1 Discussion
Jun 2, 2014 08:10 AM
jeffry
Nov 7, 2011 05:05 PM
