A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
VCDS - Oil levels
Old 05-16-2014, 01:40 PM
StanAccy's Avatar
Default VCDS - Oil levels
Does anyone know what the min and max oil levels should be as reported using Vag-Com/VCDS for a B8 8K Audi A4 (2009 Model), 3.2 v6 automatic?
I just had my oil changed (since it was time and the oil low indicator was on), and the garage said they put 7q in but the low oil indicator is still on.
Ive grabbed the info via VCDS (shown below) so if anyone can post similar logs it would be helpful.
Friday,16,May,2014,16:54:46:60385
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.5.1.0
Data version: 20140515
VIN: WAULK78K5xxxxxxx License Plate:
Address 01: Engine (8T0 907 559 G)
16:54:37
266 Oil temperature 34 °C
469 LOIL_DYN 14.8125 mm
470 LOIL_DYN_TMP 13.5625 mm
471 LOIL_MAX_SRV_INTL 14.8125 mm
472 LOIL_MIN_SRV_INTL -0.6875 mm
473 LOIL_SUM_SRV_INTL 3667.93750 mm
495 LV_LOIL_L_WARN 00000001
496 LV_LOIL_L_WARN_ACT 00000000
497 LV_LOIL_L_WARN_TMP 00000001
Im going to add some more incrementally and watch how this changes, but knowing where it should be (rather than just "add another 1q") would be nice to know. Also, having a darned dipstick would be nice...
Old 05-16-2014, 04:02 PM
StanAccy's Avatar
Added 0.5q, low oil still on:
Latest VCDS:
Friday,16,May,2014,19:22:49:60385
19:22:23
008 Calculated oil temperature 82
055 Status of oil pressure switches-Oil pressure switch for low pressure closed
056 Status of oil pressure switches-Oil pressure switch for high pressure Open
266 Oil temperature 96 °C
470 LOIL_DYN_TMP 12.9375 mm
473 LOIL_SUM_SRV_INTL 10395.31250 mm
As far as I can tell, nothing there has increased so Im guessing Im not looking at the right fields in the engine controller.
Old 05-16-2014, 05:37 PM
snagitseven's Avatar
Best bet is to get the $27 dipstick (for 2.0T engine). If the dipstick level is correct, you may have a faulty sensor. Don't add more oil until you check it with the dipstick.
Part number 06J115611E
http://www.ecstuning.com/Audi-B8_A4-...ch/06J115611E/
Old 05-16-2014, 10:02 PM
audi8k's Avatar
The specified oil volume for the 3.2FSI (I had before) is 6.2 liter (including filter change).
I'm not sure about your measuring unit (is it 1/4 US gallon?) but I think 7 of those is already too much.
My car came (new) with a dip stick, but I don't know what part nr it was.
I don't believe it is the same as 2.0T.
Info here http://www.a5oc.com/forums/a5-s5-top...indicator.html
says:
OEM Oil dipstick for 3.2 FSI: 06E 115 611 H
Old 05-17-2014, 04:54 AM
says:
They are different but unless the OP has a 2009 A4 with a 3.2 (the only year that engine was available in the A4 B8), the dipstick I listed is for all B8 A4s which otherwise only offered the 2.0T engine.
Old 05-17-2014, 07:10 AM
audi8k's Avatar
I read in his post "B8 8K Audi A4 (2009 Model), 3.2 v6"
Old 05-17-2014, 01:52 PM
oaktreelimb's Avatar
I would first check engine hood switch. Make sure the hood open display is on instrument cluster when you open the hood. If it does not detect the hood open/close, it will not update engine oil level.
Old 05-19-2014, 02:15 AM
StanAccy's Avatar
Thanks for all the suggestions. My engine is 3.2l US/North American spec, measurement unit for oil capacity isus quarts. I checked the hood latch - I don't see any change on the dash with the hood open so I'll see if I can extract the microswitch inside the latch mech and check it.
I read somewhere that I can read the hood latch state using [46]-MB26. Does anyone know if this is correct for the B8 A4s?
Old 05-19-2014, 05:30 AM
Argh.. you're absolutely correct. I missed that in the post.
Old 05-19-2014, 05:39 AM
StanAccy's Avatar
Quick update. After hooking up VCDS this morning, and checking both Controller 46, MB26 (which is the hood latch - I confirmed that) my hood latch sensor was in the closed state, regardless of whether the hood was open or closed. This was also confirmed by turning the wipers on and popping the hood - the wipers didnt stop.
Now the possibly interesting bit - I ran a full VCDS autoscan on the car, with debug level set to 2 (I was going to send Ross-Tech the info) and mid-scan (the scan takes several minutes), while the hood was popped up, my dash suddenly alerted me to the fact that the hood was open, and then immediately thereafter I received another message that my oil level was ok, and everything was full, and the low oil warning went off.
I've opened the hood almost 20 times in the last couple of days, and nothing had happened. Id had the hood popped open for about 5 mins this morning, and it was only during the auto-scan that things seemed to start working. I've since checked the hood latch state (both on the dash and in VCDS) repeatedly (I'm sure my neighbors think Im crazy), and the latch sensor is working every time. I'm wondering if the full auto-scan in debug mode triggered some sort of reset. Just theorising here.
I ran a full auto-scan (in non debug mode, debug level = 0 ) on Friday afternoon, so the only thing that was different today was the debug level being set to 2. Or its just complete coincidence and the hood latch magically started working again.
Quick Reply: VCDS - Oil levels
